Radiator hose size - Ford Powerstroke Diesel Forum
Old 11-11-2011, 06:35 AM
Radiator hose size
Have a 2006 dually and I need to know the size of the radiator hose lower outlet diameter and if the water pump outlet on the other end is the same. Also, the length of the hose in total. Summit racing has stainless hoses that can be bent to fit with rubber end connections. I have tried several hoses from NAPA and they are not even close to fitting. My dealer gets the hoses from NAPA and does not supply the correct hose from Ford. So I thought I would make one that fits. By the way, if anyone has ever changed this hose, you know it has a lot of bends.
