ECT/EOT GUAGES - Ford Powerstroke Diesel Forum
Old 11-09-2011, 11:14 PM
ECT/EOT GUAGES
Hey guys want to put in the EOT and ECT guages in my truck. From what I've seen most people say to go with Autometer. Wondering your thoughts,and where you can buy them. Thanks in Advance
Old 11-10-2011, 02:57 AM
By the time you allocate funds for the gauges and necessary senders, and allocate the time for wiring and installation, you really are better off getting an OBD-II based monitor like an Edge CTS/CS. Units like this will display a great deal more information than merely the ECT and EOT data.
The general consensus on the board is to go with something OBD-II based in an effort to display as much information as is possible.
Old 11-10-2011, 03:02 AM
Powerstroke Techie
Personally I wouldn't waste my time with manual gauges. Installing them isn't super easy. Unless you like the look of a bunch of gauges.
I'd recommend getting an edge insight CTS or CS. It plugs into your OBD 2 connector and allows you to see all the PIDs/data that the PCM is seeing. You can have up to 8 pids displayed so you can monitor all sorts of info. They have a pod that mounts it on the top left of your dash and it's out of the way of the windshield.
You can use it to check codes, monitor FICM voltage, and a whole bunch more. You can even get an EGT probe and use it to monitor EGT temps. The whole setup with an EGT probe is going to run you around $450 though. Just my 2 cents.
Old 11-10-2011, 03:38 AM
Or just get a Scangauge 2 from Autozone or elsewhere. It doesnt do egt's but does most other things such as ect and eot's. O yeah and its only $150.
Feedback Score: 3 reviews
I prefer analog gauges, but that could just be my age showing!LOL!!
You can even check out ScangaugeII for around $160, this will allow you to monitor way more than ECT/EOT.
Ebay has had Scanguages for $115 shipped a couple weeks ago. Doesn't get much cheaper than that.
Old 11-10-2011, 10:26 PM
THANKS GUY'S
Old 11-11-2011, 03:17 AM
While people are talking Scanguages , does anyone have the X-guage codes for oil presure I could not find it on the web site
Old 11-11-2011, 03:44 AM
Here's a whole bunch.
Some Scangauge II Codes for "Xgauge"
Old 11-11-2011, 04:56 AM
Lilpooh I looked through the list a couple of time's and do not see oil pressure, I do see the temp. but not the presure.
