Cutting/welding the frame... - Ford Powerstroke Diesel Forum
post #1 of 18 Old 11-09-2011, 09:34 PM Thread Starter
BubbaJ's Avatar
Well I've been tossing around the idea, of buying a single cab long bed. 4x4, pad, and cutting the frame to allow for a shortbed, then cutting the frame on my current truck and lengthen it to allow me to swap beds...
Is this do-able? As long as its done right, maybe boxing in the frame around the cuts??
I'm looking to build a drag truck, and also make my truck a CcLb,..
Uhhh... Wait... What...
2005 F-250 PowerStroke 6.0 ** SOLD***
BubbaJ is offline
post #2 of 18 Old 11-09-2011, 10:03 PM
_Hammer's Avatar
long bed to short is one thing, but short bed to long sounds iffy. I wouldn't wanna tow much with the short bed conversion much less the LB conversion.
06' 6.0 cc/sb lariat FX4
Leveled 2" on 295's
egr delete
Motorcraft filters
2000 GT Modded Modular
_Hammer is offline
post #3 of 18 Old 11-10-2011, 04:44 AM Thread Starter
BubbaJ's Avatar
The shortbed conversion would be strictly a 1/4 mile truck, so no towing for it. The lb conversion would use the same piece of frame cut from the longbed, so I had the correct lengths, Then after welding it in, I would fully box in the frame a good 4 feet where the welded piece was.
BubbaJ is offline
post #4 of 18 Old 11-10-2011, 05:49 AM
PerformanceMachineMFG's Avatar
What kind of welder are you going to use? Whatever the case may be you will need to make sure you get a good burn in which it sounds like you know. You going to use c channel to box the frame? Using c channel would definitely keep the frame from fatiguing but it still falls back to the welds. Keep me posted, I want to do the same thing to my little beater.
-Matt H
Performance Machine & MFG.
Manufacturers of High Quality EGR Delete Kits for 6.0L, 6.4L, & 6.7L Powerstroke Diesels
Toll-free: 877-408-3256
E-mail:
PerformanceMachineMFG is offline
post #5 of 18 Old 11-10-2011, 06:13 AM
Slacker
Evil Eye's Avatar
Quoted: 209 Post(s)
Feedback Score: 4 reviews
You might try talking to Gene Feldhans; he goes by the screen name of weweld on many of the forums. You can say he has done some frame modifications to a few racing trucks.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #6 of 18 Old 11-10-2011, 06:42 AM
That's a fitting screen name.
-Matt H
Sent from my Autoguide iPad app
E-mail:
post #7 of 18 Old 11-10-2011, 11:37 AM Thread Starter
BubbaJ's Avatar
-Matt H
I would not be doing the welding myself, I know "how" to weld, but I would never trust myself to doing something like that. But I have a buddy that is very experienced in welding, and knows a lot about boxing frames and such...
I just want to make sure it can withstand a 1000+ hp diesel...
BubbaJ is offline
post #8 of 18 Old 11-10-2011, 01:48 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
It isn't necessary to box the frame. There have been a couple of conversions here on the org if you look around. Very cool to have a reg cab short bed SD.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 18 Old 11-10-2011, 02:37 PM
I havent looked at my SD but my 2000 F150 the frame is actually rivited together right behind the bed. There is also a crossmember at that connection. Maybe its the same way on the SD. You could just bolt it back together what ever way you want... wouldnt hurt to run a bead at the connection also
Nov 2003 built
2004 PSD F250.
SC Long Bed SRW
EGR delete, Studs, Swamps FICM, 4" turbo back
lightninmike is offline
post #10 of 18 Old 11-10-2011, 02:46 PM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
i would be scared to do this. im sure you know a welder around your parts somewhere. people cut and extend tractor trailer frames all the time and they are good for 80,000lbs. that has to mean something. or bit the bullet and trailer it to a shop and have them weld it. i dont think you would have to box it. jut reinforce it with a plate on the outside maby 3 feet long areound the weld. but im not a pro welder by anymeans soo....
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
