FICM code on insight cs - Ford Powerstroke Diesel Forum
Old 11-07-2011, 06:35 PM
Checked insight for diagnostic codes just for sh**s and giggles and found P0611 code even though there was CEL. I've read that this is FICM code. I read that someone checked their FICM voltage with insight CTS. Figured I could do it with CS but can't figure out how. Thought the only difference between them was the screen, the capabilities being the same. Either this assumption is wrong or I need some guidance on how to accomplish this. Also truck seems to be perfectly ok, I wouldn't know anything was wrong if the code wasn't on cs. Any advice on either the insight or FICM is appreciated.
Old 11-07-2011, 06:43 PM
DBM DBM is offline
if the firmware on your CS is up to date, it should have FICM voltage as on of the things you can monitor...
Old 11-07-2011, 06:45 PM
Almostdunfukinwidit
Update the firmware using fusion and you will have FICM voltage
Old 11-07-2011, 06:46 PM
Might have to update your cs via the software. Update your cs then check your ficm voltage.
Old 11-07-2011, 06:57 PM
Y'all make it sound so easy but I have no idea how to get this done.
Old 11-07-2011, 07:03 PM
I also sent it back to EDGE in July of this year because it quit and in their letter they said they updated all the software. I would've thought that's pretty updated.
Old 11-07-2011, 07:09 PM
DBM DBM is offline
The latest update came out after that... when you turn on your key, read the screen, it should tell you what version firmware it has, probably version 2., the new version is version 3.
Old 11-07-2011, 07:28 PM
So do I send it in again or what? Thanks again for the help.
Old 11-07-2011, 07:55 PM
You should be able to download the Edge Fusion software to your computer from Edge's website. I want to say when I hooked my CTS to my computer the first time, it came with the software, or automatically loaded it... One of the two. But you've gotta have the USB cable to connect it to your computer... Which I'm assuming you have?...
Old 11-07-2011, 08:00 PM
You would think it would've got filed under don't ever lose this, you're gonna need it. But, I can't seem to find that file.
