cheapest place to get a cat and muffler delete? - Ford Powerstroke Diesel Forum
Old 11-06-2011, 02:37 PM
Feedback Score: 5 reviews
Hey guys Im gonna be doing a cat and muffler delete and just add a tip to the stock exhaust and I was wondering where the cheapest set is sold. Let me know guys-
Old 11-06-2011, 02:51 PM
information regurgitator
For the stock system, the only place I have seen a bolt on set of delete pipes is:
Cat delete: 03-07+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
Muffler delete: Ford 6L Powerstroke Diesel Stock Muffler Delete Pipe
Old 11-06-2011, 04:05 PM
Just take it to any local exhaust shop and tell them what you want done.
Old 11-06-2011, 04:59 PM
well I was looking for the ability to put the exhaust back on if I need to for emissions so I like the bolt in designs and thats why Im not doing a traditional exhaust
Old 11-06-2011, 05:01 PM
If you want to be able to take it off and put it on at will, you shouldn't use u-bolt style clamps. Use the band clamps. The u-bolts will dent the pipes, making them harder to take apart.
Old 11-06-2011, 06:06 PM
What he said, you can get the clamps at napa for about $12 a piece, They are what I used on my MBRP system after I had a bad experience with u bolt clamps, The factory hangers needed some tweeking to work with the band clamps but everything fit with some persuation.
Dik
Old 11-07-2011, 11:36 AM
You will spend a little more money but if I were you I would just get the MBRP turbo back kit. If you need to add the cat back some day I'm sure a local muffler shop can help.
Going the MBRP route will get you a larger down pipe which will help with flow.
Old 11-07-2011, 12:58 PM
yea I havent seen a great improvement with the 4" full exhaust and its a pain to do the down pipe, EGT temps were maybe within 20 degrees of what they were so I figured Id go this route incase I ever get stationed in CA or some retarded state
