put new oil cooler on today!!! - Ford Powerstroke Diesel Forum
Old 11-05-2011, 03:27 PM
i went with the ford oil cooler again cause i got a good deal on one, started yesterday around 11 or so and stopped around 6 after tearing everything downand putting the the oil cooler back in. then today started around 9 and finished every thing around 2 and truck was running again... the delta before i changed it was around 23 degrees and today after driving for a couple of hours it was no more then 2-3 degrees apart.
thanks to eric schnoor for helping me haha you are the man....
have a question though.. should i put a coolant filter on it???
Old 11-05-2011, 04:00 PM
Feedback Score: 3 reviews
Yes sir, put a coolant filter on it.
Did you get a chance to cut open the old oil cooler?
Old 11-05-2011, 04:05 PM
ok sounds good, will that prevent it from clogging again???
but yes it was full of sand and gunk hah it was clogged to say the least, if i had to guess it was going to blow any day...
Old 11-05-2011, 04:12 PM
A coolant filter will filter out casting sand and rust scale, but it won't help with silicate drop out. This is where a ELC silicate free comes in handy.
It's a good feeling to do your own work, not only did you save money, but you get familiar with the motor.
Old 11-05-2011, 04:19 PM
yea man i think im going to get one just for peace of mind...
yea for sure. its just little room to work with and time consuming.. hoping this cooler holds out
Old 11-05-2011, 04:53 PM
Question, if you use a silicate free ELC and you use a coolant filter would that be enough to prevent another oil cooler failure of the original ford oil cooler? I was looking hard at going the Bullet Proof Diesel route next spring along with ARP headstuds but the only gripe I have with the BPD oil cooler is it takes out the factory fog lamps. As someone who suffers from night blindness I really need those extra lights on roads I'm not familiar with know what I mean?
Old 11-05-2011, 05:29 PM
here is a pic of one of the holes of the oil cooler. thats how it came out... i stuck a screwdriver in it and there was a clump triple this size that came out
Old 11-05-2011, 07:04 PM
That's not true. They really don't sell the bumber mount anymore and the condenser mount doesn't interfere with the fog lights in any way. THE BPD is the only way to be 100% sure that you have put the problem behind you.
Old 11-05-2011, 07:07 PM
Feedback Score: 7 reviews
Coolant filter is good insurance-it's a bypass design, so at any given time it is only filtering around 10 percent of the coolant-it's not a substitute for using GOOD elc coolant and keeping it clean, but it will keep rust flakes, casting sand and other particulates in the system from staying there.
Old 11-05-2011, 07:14 PM
oh ok. when i flushed mine the coolant was clean as could be.. so that was a good sign i guess but im pretty sure there was ford gold coolant in there so im hoping thats what clogged it a long with casting sand... hopefully this one holds haha got my fingers crossed i dont wanna tackle that again for a while...
