6.0 Oasis Report Request
Looking at going from a cummins back to a powerstroke just like to know a little more about the history. VIN is 1FTNW21P93EC97370 please send to shane.ryan.murphy@gmail.com
Thanks in Advance, Shane |
It's alot to email so i'll post the meat of it here
1-29-04 Mid-State Ford 5972 miles Reprogrammed PCM,TCM,and FICM for check engine light Another reprogram at 38k miles 3-28-07 Stivers Ford 48535 miles RUNS ROUGH COLD START UP,WARM ENGINE IS OK Tech Comments: VERIFIED, REPGROGRAMMED FICM PER TSB 07 05 04. RECHECKED, STILL HAS CONCERN, VISUAL INSPECTION, OIL, FUEL OK. IDS TEST B132B, POWER BAL, #4 MISS. FUEL PSI OK, REPLACED #4 INJECTOR, FOUND EXHAUST LEAKING. BOOST TESTED, REMOVED TURBO AND REPLACED Y PIPE CLEARED CODES. RETESTED OK. |
continued repair from above
INSPECT ADVISE OIL LEAK, THINKS REAR MAIN Tech Comments: ICP LEAKING, CAC TUBES LEAKING, OIL PUMP REGULATOR LEAKING ENGINE OIL LEAKS DIAGNOSIS thats the last warranty repair,not too bad one injector,up-pipe, and icp leaking which is common on 03s early 04s |
thank you very much.
The studs, egr, and cooler were replaced by the dealer according to the lot that has it now. I guess the original owner paid for this on his own. |
2003 Ford F-250 SD Crew Cab Lariat 4x4 - Auto Drive Inc.
what would a good price be on this truck this seems a little high for an 8 year old truck even with the lift/tires |
well i just paid 15 for my 03 its almost the same except for cloth seats,7.3,and factory wheels so i say that price isnt too bad
@ dieselflash... Do you think that you could run an oasis report for this VIN # ??
1FTSW21P26ED39157 Thank you in advance. |
CLINTON FORD LINCOLN 13845 miles 31-AUG-07
Customer Comments CUST STATES DRIVERS OUTSIDE MIRROR GOES SIDE TO SIDE BUT NOT UP & DOWN Tech Comments VERIFIED NO UP & DOWN MOVEMENT THRU ELECTRIC MIRROR REPLACED MIRROR ASSY RETESTED GOOD CLINTON FORD LINCOLN 20598 miles 08-JUL-08 Customer Comments CHECK ENGINE LIGHT TROUBLES Tech Comments DIESEL DIAG PERFORMED SELFTESTS KOEO PASS KOEC P0299 KOER PASS. PERFORMED IDS EGR TEST PASSED. CLEARED CODES. UNABLE TO VERIFY CONCERN AT THIS TIME. CLINTON FORD LINCOLN 23982 miles 09-MAR-09 Customer Comments CHECK ENGINE LIGHT TROUBLES STATES COMES ON WHEN PULLING BOAT, ETC, ADVISE Tech Comments REMOVED TURBO AND DISASSEMBLE TURBINE SIDE AND INSPECT, FOUND CORROSION, REPLACED CENTER ROTATINGHOUSING ASSEMBLY, CLEANED VANE SET AND REASSEMBLE REINSTALLED TUBO AND RETEST |
