Back into a diesel, a few new questions... - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-02-2011, 06:23 PM Thread Starter
Okay, back into a diesel after our last truck, was nefariously adopted by someone else late at night. Picked up a replacement just a bit ago. It was a repo that we had fixed up.
This one supposedly has an edge chip on it. I understand that EDGE chips are very hard on transmissions. Where can I find it and how can I get the tune back to stock. I also noticed an edge EGT probe, bonus!!, tonight while changing the oil and looking over it further, hopefully that will adopt well to our new insight CTS.
Also, the grommet where the EGT passes through the firewall is gone. Can i get one at Napa or do I need to go to ford?
Getting the Ravelco installed tomorrow, hopefully this one will stay around a little longer. Thanks for the help in advance.
Starr_302 is offline
post #2 of 2 Old 11-03-2011, 12:45 AM
The Edge pyro will not fit on the new Edge Insight CTS what i'm going to do is get the Y and install the Edge CTS and use both at the same time you can't have to many gauges.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
