New to diesels, not to DIY - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-31-2011, 05:55 PM Thread Starter
Hey all, like the title says I'm new to diesels, I just picked up an 05 Excursion with the 6.0l. I have read the post on bulletproofing the machine (great write-up BTW). So I have a couple of questions, sorry if there is a similar post it existence.
First off, I am having a hard time finding diesel products at auto parts stores, what types of resources are generally available for these type engines? More specifically, I have all the hardwares for a coolant filter job, just no fluids (Restore, Restore+, Rev-x). Side question: (Lowes didn't have 3/8" rubber heater hose, however they had clear reinforced hose of the proper size, I want to say it was vinyl. It was rated for a higher PSI @ 70* than the rubber, it was cheaper, also I was assured by the sales gentleman that it would not be affected by the heat, does this sound legit?)
Secondly I plan on doing a EGR delete, I am thinking this kit: Complete EGR Delete Kit Ford Powerstroke 6.0
anybody had experience with this company?
And finally, I have plans to eventually do a remote oil cooler/spin on filter build. While wondering around the parts stores today I stumbled upon transmission coolers, just small radiators, couldn't one of these be rigged and mounted in tandem with a filter base similar to the one I just got for my coolant filter build?
I realize this is a lot at once but it should keep the thread active for a while.
I plan on keeping the gurus on their toes.
Also I am sure there is a universal forum etiquette and I apologize in advance if I am in violation of said customs.
chad.blevins1 is offline
post #2 of 8 Old 10-31-2011, 06:09 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
First and foremost, welcome to the ORG.
You have some homework to do on the oil requirements of this engine. The peak flow demand of the engine is close to 18.5 gallons per minute. Try pushing that flow though those little coolers you saw. It takes a 3/4 inch hose to get in the ballpark of that flow rate. There is a thread around here by windrunner..(he might have a number after his name?.?.?) that shows what he did to accomplish his remote oil cooler. Its alot of work and his isn't exactly perfect as far as pressure drop across the system. It is still a work in progress, and I am paying close attention to the details that are coming out of that thread. Very informative.
As far as your egr cooler delete kit choice, all egr cooler delete kits are pretty much the same. I haven't run across that particular one, but it would likely work just fine.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 8 Old 10-31-2011, 06:10 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
I found the thread by windrunner408:
Oil Cooler Delete
Please
post #4 of 8 Old 10-31-2011, 06:16 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Before you buy anymore parts, do some more research.
That clear hose you bought might be rated for the PSI, but what about heat and chemicals?
Your not gonna build a external oil cooler from parts at your local auto parts store, no way!
Start with a monitoring solution, you need to check the health of the motor first, then Tackle the issues.
The bulletproof thread you read was a great start, here is some more.
Things to consider about owning a 6.0L
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #5 of 8 Old 10-31-2011, 07:51 PM
Personally I would stay away from some type of spin on oil filter unless you are adding a by-pass oil filter. If your cooling system is in good health and you tranny fluid and tranny are in good shape the stock system does a good job of keeping the tranny cool unless you are going to be pulling a heavy trailer all the time. My tranny temp rarely goes above 165* when empty. And by all means do some more research before you tackle this vehicle.
2004 F250 6.0L CC SWB 4x4 (name's Eleanor)
Straight Piped, Coolant Filter, EGR Delete, Blue Spring'd, Amsoil'd, ELC'd, Rev-x'd, S&B Intake
JumpinJack is offline
post #6 of 8 Old 11-01-2011, 04:41 AM
"Stroker 8"'s Avatar
Quoted: 4 Post(s)
Larry
2015 F-350 CCLB DRW, Lariat Ultimate,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Tuxedo Black W/Charcoal Black Int.,
14,000 LB GVWR,
3:73 Gears W/Limited Slip,
17" Polished Forge Alum. Wheels,
BFG All-Terrain Tires,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Chrome Pkg.,
FX4-Off Road Pkg.,
Upfitter Switches,
Engine Block Heater,
9025 Lbs. on the CAT Scales.
"Mack Daddy Scorpion!"
"Stroker 8" is offline
post #7 of 8 Old 11-01-2011, 04:44 AM Thread Starter
Thanks for the advice, I have no intention of halting research.
post #8 of 8 Old 11-01-2011, 07:29 AM
Feedback Score: 5 reviews
ToMang07 is offline
