2006 F250 SD 4X4 front brake rotor removal - Ford Powerstroke Diesel Forum
post #1 of 19 Old 10-07-2011, 07:34 PM Thread Starter
So I'm a guy who doesn't like surprises when taking on a task. I ordered some new Motorcraft front brake rotors for my SD. I was getting a some shaking when braking, had the brakes inspected and they said I needed new rotors. Old ones could not be turned.
So I'm gonna do this job myself and wanted to know if there was anything I should be aware of, tools I need, time saving tips, etc. ANYTHING at all!
Nu2Ford is offline
post #2 of 19 Old 10-07-2011, 07:43 PM
caissiel's Avatar
Remove the wheel, unbolt the caliper and hang it by wire and not the hose, Remove the caliper holder and you are there, very simple. Need 13mm, 19mm sockets.
2005, 6.0L, 6 Spd Std, 3.73 Rear End, F250SD, Extended Cab, 4 x 4 Long Bed. 2008 extension mirrors. GPS/TV/DVD/CD/Rear Cam/Radio installed, Max Energy programer by Hypertech, and Fuel Pressure Gauge. ScanGaugeII for 60 plus XGauges, and MPG. ELC Cat EC-1 Coolant, Pull a 39ft 15500Lbs 5th Wheel Camper Trailer. Mileage Avg is 20MPG, and pulling 12.6MPG.
caissiel is offline
post #3 of 19 Old 10-07-2011, 07:44 PM
I own a Automotive shop in Texas. Since it is a 4X4 the rotors are just slip offs. It's real easy. If your not changing out the pads all you need is a 21mm to pull the bracket off holding the caliper and pads. Just take it all off as one, unless you are changing pads too. You may have to give it a tap with a hammer, but it pops off the hub bearing. The main thing you want to watch out for is that the boxes your new rotors in look perfect. If not I would let a GOOD shop in your area turn them before you install them. I have had new rotors warped worse than the old ones from part's guys dropping them, or getting dropped during shipping.
ASHERAUTO is offline
post #4 of 19 Old 10-07-2011, 08:20 PM
Galaxie's Avatar
Childs play! Fun job that is easy!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 19 Old 10-07-2011, 09:06 PM Thread Starter
Well guys that sounds suspiciously easy. The boxes are in perfect condition and I have the suggested socket so I think I'm gonna take a crack at it tomorrow. Thanks for the input.
Nu2Ford is offline
post #6 of 19 Old 10-08-2011, 03:35 AM
Very true... I have had many new rotors in the box come warped. I always have my new rotors turned down before I install them. Its not all new rotors but you would be very surprised at how many new rotors come this way.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #7 of 19 Old 10-08-2011, 03:47 AM
work&play's Avatar
Quoted: 2 Post(s)
I am going do be doing rotors on my 07 DRW.
Do you guys have any tips for the rear.
I know the axle shaft needs to come out.
2007 6.0 PSD,F350 4X4 Lariat,CC, DRW,9' Knapheide body, stainless steel lader rack, SCT with custom tunes, ARP's, EGR delete, ITP RR, Airdog II 130/75, Garrett Powermax, Banks turbo back, Firestone air bags, Autometer gauges
work&play is offline
post #8 of 19 Old 10-08-2011, 06:06 AM
A big heavy hammer is good for when it's rusted on.
2006 Ford F-250 Crew Cab 4wd XLT 6.0 Powerstroke Diesel
  • Rev-X Oil Additive and Archoil AR9100 Reviews(Check out my videos:
losbanosf250 is offline
post #9 of 19 Old 11-14-2012, 04:09 PM
i have a 2006 f250 4x4 and was in the process of replacing pads and rotors up front due to warped rotors
i removed the caliper and mounting bracket and i thought the rotor was just rusted tight, but after beating on it with a wood block and a hammer it wouldnt budge
i thought it just slipped on over the 4x4 hub, but maybe i'm wrong...?
any suggestions or get a bigger hammer?
thanks!
joshc697 is offline
post #10 of 19 Old 11-14-2012, 04:22 PM
Bigger hammer! I smacked the rotor directly (it's getting replaced, why not?) while spinning the rotor. It will pop off.
sent from a dumb guy with a smart phone
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
