Head Gaskets Without Pulling The Cab... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-05-2011, 04:13 PM Thread Starter
goXtreme's Avatar
Quoted: 3 Post(s)
Send a message via AIM to goXtreme Send a message via MSN to goXtreme
I am extremely short on money right now and I just popped a head gasket and am seriously considering trying to pull the heads in my garage to save the money on labor.
Of course I will be going back together with ARP's, but I am a little leary about doing this as I am NOT a small man and am afraid that I will not be able to get in where I need to and able to lift the heavy a$$ed heads out of there, plus have the knowledge to put it all back together.
I know that there are some good write ups on here (Lumberg's), but I am still a little worried.
Could I possibly just lift the cab just enough with a jack to get the heads out????
'03 F-350 6.0 CC LB 4X4:
4" MRBP Turbo Back, No Muff, S&B Intake, Sinister EGR Delete, SCTX3, Edge Insight CTS, Blue Spring, Zoodad, Optima Yellow Tops, DIY Coolant Filter,ARPs, B&W Turnover Ball (W/ Companion Hitch), Ding Ding Mod, 2 1/2" Leveling Kit, 17" Wheels, BPD Fuel Filter Cover, AFE Rear Diff Cover, BPD Oil cooler & 58 Volt FICM, S&B Intake horn and coldside CAC tube
goXtreme is offline
post #2 of 9 Old 10-05-2011, 04:43 PM
mcflan's Avatar
Feedback Score: 9 reviews
You can do incab heads and studs. There is a write up on here in the tech files:
DIY, In Cab HGs & ARPs
Jon
03 6.0 F350 SD
SCT w/Matt's SRL
Zoodad
AFE Stage II
EGR Delete
Banks Monster Exhaust
Isspro Gauges
Studded, Lapped, and Bored
175cc Injectors
Powermax Turbo
Blue Spring FPR
Diesel Site Coolant Filter
AD2 Fuel System
Oil By-Pass System
My personally made Remote FICM/Board
mcflan is offline
post #3 of 9 Old 10-05-2011, 05:15 PM
smokersteve's Avatar
Quoted: 20 Post(s)
srmastertech has video documentary on how to lift the cab and replace the head gaskets.
You can do it with the cab on but it will be difficult due to the smaller space.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #4 of 9 Old 10-05-2011, 06:09 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
I've done partial cab lifts on 6.4s with 2 jacks before. It could definitely be done on a 6.0 but I don't see a big advantage in doing it. the space is tight but the hardest part(and biggest advantage to pulling the cab) is the final torque down
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #5 of 9 Old 10-05-2011, 06:55 PM
Check my sig for vids
Turbo cleaning
HG In Cab:
Leaky Oil Pan Bedplate:
FICM testing
If you think the 6.0 is bad.....Get a 6.4
Rotbody is offline
post #6 of 9 Old 10-06-2011, 07:47 PM Thread Starter
goXtreme's Avatar
Quoted: 3 Post(s)
Ha, I looked at your sig, the last one kills me, that might have just persuaded me to spend the cash and pay someone to do it, as little as I want to
goXtreme is offline
post #7 of 9 Old 10-06-2011, 07:49 PM Thread Starter
goXtreme's Avatar
Quoted: 3 Post(s)
Might be a stupid question but, if I was to figure out a way to lift the cab, would I have to remove the intake and all of that stuff like I did when I did the EGR delete and then the oil cooler?
goXtreme is offline
post #8 of 9 Old 10-06-2011, 08:08 PM
Quoted: 28 Post(s)
Well the intake manifold is connected to the heads. So, I say YES to removing the intake manifold.
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #9 of 9 Old 10-06-2011, 08:12 PM Thread Starter
goXtreme's Avatar
Quoted: 3 Post(s)
I guess that I should have paid more attention when I had the intake off huh?
Thanks for the reply...Still contemplating on taking it somewhere...Grrrr
goXtreme is offline
