How long can you keep an engine block heater plugged in? - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 30 Old 09-15-2011, 04:30 PM
the chad's Avatar
I have mine on a timer for 4 hrs before i leave for work.
Chad
07 F250
4'' MBRP to 7'' FTE Miter
ELC w/ Sinister Coolant filter
ARP's with OEM
Edge CS and Trans, Boost, FP on the pillar
Voltmeter in dash
Banjo's
Looney
Cal-Tracs
20x10 Monsters wrapped in 305 420s
RCD Egr Delete
Warren 190/75
Dozers RR
MTW Stage 2
557 hp/1206 ft/lbs
Big thanks to JJ @ Dozers And Adrian at MTW
the chad is offline
post #12 of 30 Old 09-15-2011, 04:40 PM
Powerstroke Techie
Quoted: 15 Post(s)
Garage
Feedback Score: 4 reviews
same, can't beat a block heater for these oil burners
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #13 of 30 Old 09-16-2011, 05:05 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
A thread on block heater temps:
Block Heater Temps...by the hour.
The test I did last winter:
This morning I plugged the block heater in. My Scangauge read 39 degrees.
1 hour later it was 80 degrees.
2 hours later was 94 degrees.
3 hours later it was 103 degrees.
4 hours later it was 110 degrees.
5 hours later it was 116 degrees.
Yes, 39 isn't that cold to start, but was interesting to see that it went from 39 to 80 in an hour.
Currently my oil temp in hour 3 is 77 degrees. It was 40 at starting point.
Oil temp after 4 hours is 91 degrees.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #14 of 30 Old 09-16-2011, 07:34 PM
Galaxie's Avatar
I plug mine in on a timer for 4 hours. The first year I had my truck I left it in all night. Saw a slight change in the bill. Nothing much. $20 more a month about.
A friend of mine leaves his in all night, but he is on call and might need to leave any time.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #15 of 30 Old 09-16-2011, 07:36 PM
HarrisonB.'s Avatar
4 hours is perfect. anything more and it really dosent heat up much more or is necessary. tho leaving it plugged in overnight wont hurt
HarrisonB. is offline
post #16 of 30 Old 09-16-2011, 07:40 PM
For anyone in the Midwest needing a block heater cord O’relliy auto parts has them for $19. P/N ZRO 360-0008. My local ford dealer wanted $115 for the cord alone.
HAM_RADIO_MAN is offline
post #17 of 30 Old 09-16-2011, 08:51 PM
smokersteve's Avatar
Quoted: 20 Post(s)
I stopped this year. I only used the block heater because I babied my truck. Once I realised that it was a truck, I stopped. I use Mobil 1 5w-40.
I have no stiction issues so far. At home central California, temps are 40*-120* year round. Tahoe it gets allot colder. Once It is below 40 in Tahoe I use the block heater. I like to have a warmer truck when I hop in, and it is better longevity wise. I started my truck when it was 20* block temp with out the block heater and I had no issues what so ever.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #18 of 30 Old 09-16-2011, 09:05 PM
at about what temps would you start to see harder starts? Sorry to go off on a tangent.
stockd15b is offline
post #19 of 30 Old 09-16-2011, 09:16 PM
Buffalo444's Avatar
well last winter it was about 50-60*, but with 390k mile injectors that was expected. this summer it was about ninety... truck just didnt want to start after the block air vent mod
Jason
First rig: e99 F250 CCSB 4x4 auto, white, 388k miles: traded in
Then: 02 F350 RCLB SRW 4x4 zf6, silver, 201k miles, THREW A ROD
: traded to Jake
Now: 96 F350 CCLB DRW 4x2 auto, red and silver/grey, 266k miles: rusty but trusty
Buffalo444 is offline
post #20 of 30 Old 09-16-2011, 09:17 PM
Quoted: 20 Post(s)
probably 10* and below. If you have a clean system then you will not have any issues that low in temp with 5w-40 oil.
FICM Testing Videos
