6.0 life span - Ford Powerstroke Diesel Forum
post #1 of 14 Old 09-11-2011, 06:55 AM Thread Starter
6.0 life span
hey guy's,
been looking at an 04 with an 03 sticker on valve cover,
at what i believe to be a good price.
having heard of 6.0 issues i have been looking at all the info i can.
thank you all very much for the info.
i think i understand and i am ok with the things that need to be done
to bullet proof ie: egr, oil cooler, coolant, ect.
but what concerns me is seeing that 200k miles are what is
expected out of this motor without some internal engine rebuild.
is this what is expected?
are the 400k - 500k miles before overhaul day's gone?
i haven't had a diesel since 07 when i had a 96 7.3 and 03 5.9
that i had for trouble free years.
i expected 400,00 out of each of those.
things changed for me in 07 as it did for many and i went back to gas.
things are better and i now drive 200+ miles a day for work and was thinking of going back to diesel for engine longevity,
because i know i'm on borrowed time with my 206k mile f150.
the 04 i'm looking at has 150k and i don't want to spend the money on a truck that has little more life before rebuild than the one i have.
sorry for the long post but with money tight i just need to make a good decision. thanks to all again.
rick
drrick7 is offline
post #2 of 14 Old 09-11-2011, 07:11 AM
The Silent Service
colo_dually's Avatar
Quoted: 13 Post(s)
Pull the Oasis report and the Carfax, know what you're getting into.
If you are serious about the 6.0L, go ahead and get a ScangaugeII or Edge Insight CS/CTS and hook up and get a solid set of temps before you buy. If you can't do that, have a Ford Dealership do a full mechancial inspection and determine the temps for you.
If the temps are too high, the Oasis isn't clean, or the inspection comes back with something, walk. There are a number of folks selling 6.0L's and its a buyers market if you know where to look.
As for longevity, I'm expecting an overhaul at 300k, maybe a little earlier. There are a few 6.0L's out there approching the 500K mark, and still going.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 14 Old 09-11-2011, 06:24 PM Thread Starter
thanks colo.
no one else has an opinion on what the average life
span is on this motor?
i understand there are variables, but to only
be averaging 250k seam like a short life for a diesel to me.
if so, the 6.0's may be to rich for me.
drrick7 is offline
post #4 of 14 Old 09-11-2011, 06:29 PM
2003kingranch's Avatar
buy a 6 speed 7.3 and be done with it. with good maintenance you will see 400-500k without to many problems.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #5 of 14 Old 09-11-2011, 06:37 PM
0660BigHoss's Avatar
I just bought mine about a month ago and one sticking point with me was that it had to be a 06 or 07. 03-05 just seemed to have the majority of the issues. Some of those issues (certainly not all) got addressed by 06-07.
Good luck with your purchase!!
2006 F-350 SC 4x4 6.0 LongBed
W/ Banks Big Hoss Bundle and IQ Tuner
2008 Center Console
High Idle Mod
Fumoto F-111N,
BPD 6 PHASE 58V FICM
BPD EGR COOLER
BPD UPGRADED OIL COOLER
ALL ALUMINUM RADIATOR
HPOP FITTING UPGRADE
Blue Spring Mod
Rancho RS9000 XL's
No Payments Mod
Pioneer AVIC-X930BT - With Park Brake Bypass
Diesel Kleen in EVERY tank!!
0660BigHoss is offline
post #6 of 14 Old 09-11-2011, 07:11 PM
The Silent Service
Quoted: 13 Post(s)
Originally Posted by drrick7 View Post
thanks colo.
Its a simple matter of the emissions control equipment, and the HP to displacement. The 7.3L was blessed with no emissions gear, and a high displacement to HP ratio from the factory.
The days of the factory diesel lasting 500K are long gone.
post #7 of 14 Old 09-12-2011, 05:25 PM Thread Starter
thanks again to everyone.
had the truck scaned today, it showed
slight airflow loss through egr(big surprise)
and something with program error.
he said it could have been from last dealer update
it has had 2 different program updates and he said i should go to a dealer and get the latest update. he said it changes a few things including the way the injectors work
and helps with cold start. he feels truck is solid
and with egr block off,new oil cooler and headstuds
it should see 300k-350k. says he's seen many with that.
i think i'll be a new 6.0 owner.
thanks,
rick
drrick7 is offline
post #8 of 14 Old 09-12-2011, 08:09 PM
here is a 6.0 with 600k plus
04 6.0 Dads all stock hit high mile mark..
04 f-250 turbo back exhaust, afe intake, gauges boost coolant trans exhaust, diy coolant filter, 17" liduid metal rims, BPD ficm
ktmrider686 is offline
post #9 of 14 Old 09-13-2011, 01:59 PM
ΜΟΛΩΝ ΛΑΒΕ
craftkr's Avatar
Traded in my 2003 F250 (6.0) at 293K miles, still ran great. I just wanted a newer interior with Leather.
My 2005 F350 just hit 204k, but about 14k miles ago I sent it to powerstroke magic and had new heads etc. oil cooler egr delete etc. etc.
Take your time and look at whatever trucks your intersted in and do your homework. 6.0 is a good truck if they haven't been abused. I've had good luck with mine excluding the small fortune I put into my 05, but I did that so the truck would be good to last. Def. pull oasis, check the delta on the coolant and oil temp. Also, check the degas bottle and if you smell diesel in it be skeered!!! Read up on this site, allot of good info and knowledge. Absorb as much as you can and apply that when you go to look. Happy hunting
And I get around 14-19 mpg with my F-350 SRW. 14 town, 19 hwy
Truck is great, and with all the money I've spent on the truck I'm still in a nice diesel truck for half of what a new one would cost
_____________________________________________
Kevin
I'm not from Texas, but I got here fast as I could!
craftkr is offline
post #10 of 14 Old 09-16-2011, 07:24 AM
Chapter Director
cubalz's Avatar
If you are looking for a diesel to routinely run for 400,000 -1,000,000 miles (or more), idle all day long and ignore owner abuse and neglect -a 6.0 Powerstroke is really not the motor for you . Look no further than a 5.9 12v Cummins. Unfortunately, the Dodge bodies and chassis are total crap. I have owned many 6.0 PSD's and l love every one but even with my meticulous maintenance schedule I keep, I do not expect ANY of them to last over 400,000 miles due to the design even if with all of the preventative maintenance mods (heads decked, studs, EGR delete etc) I am a Ford guy through and through and will always run PSD powered trucks but I buy them knowing full well their limitations.
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
