Turbo spooling up - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-31-2011, 01:14 PM Thread Starter
Turbo spooling up
I noticed that when my EGR is plugged in my turbo will spool up and down while at idle but when I unplug the EGR it doesn't. Does anyone know why it is doing this?
nightkeeper62 is offline
post #2 of 5 Old 08-31-2011, 01:51 PM
RRF985's Avatar
That's normal. It's the vgt doing a vane sweep. With the valve unplugged it cancels the vane sweep and can lead to other problems.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #3 of 5 Old 08-31-2011, 02:20 PM Thread Starter
As long as it's normal. Thank you
post #4 of 5 Old 08-31-2011, 02:42 PM
You will also notice the fan does not run up to full RPM and some say the boost is limited to about 20 psi
HAM_RADIO_MAN is offline
post #5 of 5 Old 08-31-2011, 07:17 PM
FourFun's Avatar
I used to run without the egr plugged in. Matt from gearhead informed me it needed to be done for ^^^^^ reasons. But i can honestly say i don't think i've ever noticed the vanes sweep in my turbo. I must be numb to it
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
FourFun is offline
