looking to get a downpipe - Ford Powerstroke Diesel Forum
Old 08-30-2011, 10:26 AM
What is the best downpipe for my 05 f350? should i go with a 3.5 or 4 inch downpipe and what brand?
Old 08-30-2011, 01:52 PM
If you really think you need one, go with a 3.5" MBRP. It is HUGE compared to the OEM downpipe and doesn't have the clearance issues of the 4". You won't notice much if any performance improvement though. The '05 downpipe is smaller, but doesn't have the crimped/flattened sections the earlier ones had.
Old 08-30-2011, 02:16 PM
The Silent Service
If you are only doing a downpipe to the CAT, you'll want the 3.5". The 4" DPs that I have found, all are included with 4" turboback systems, and delete the CAT.
I saw a little decrease in EGT's going to the 3.5" I have on mine, and it still has the CAT.
Old 08-31-2011, 11:29 AM
well i have a proggramer and i have 4inch piping from the cat back and my cat is hollowed out so i figured i should get a dp and finish my exhaust
Old 08-31-2011, 03:31 PM
IMO I wouldn't waste the money, I bought the MBRP 4" turbo back exhaust, installed the cat back first because of the pita replacing the dp and drove it that way for a couple months. Sounded great but didn't see much other difference. Then I had the dp installed when the dealership had my engine out for bed pan seals. I didn't see much change in the egt and now have problems with the gasket between the dp and cat. Also ever since then my fuel mileage has seemed to have gone down 1 - 2 mpg. Just my opinion and experience.
Old 08-31-2011, 05:27 PM
oh wow you actually lost mpgs from it that sucks. sounds like one big headache to me.
thanks for the input
Old 08-31-2011, 05:30 PM
I seriously doubt the downpipe made you lose mileage. More likely, they reflashed your truck to the latest strategy after the engine work and the newer one gets poor mileage.
Old 08-31-2011, 07:40 PM
That was my first thought, the service writer claimed they didn't do a reflash and that it would have been in the tech's notes if they did but who knows. The current stratagy is VXC7H3 which I believe is an older one. I have gained some milage back with my custom tunes.
Old 09-01-2011, 05:03 AM
I went with a MBRP turbo-back as well and lost a bit of mileage with the same flash. I lost my mileage because my foot got about 2-1/2 lbs. heavier though
Just go with the 3.5" downpipe. Going to 4" wont make a bit of difference other than being harder to install. Oh yeah. Something I found out when I did mine on a Sunday night and having to go to work the next morning.... make sure you have a saws-all with a LONG blade. The one that most likely came with your saw when you purchased it wont quite make it......
