Just did the high idle mod - Ford Powerstroke Diesel Forum
Old 08-27-2011, 07:13 PM
I must say once I found the wires it was probably the easiest 30 minutes I have had in a while. I solder and heat shrinked the jumper in also since I don't plan on removing it.
Thanks to all who have contributed to the write up in the mod section.
Dik
Oh I wired it into Upfitter switch #4.
Old 08-27-2011, 07:39 PM
Link for said writeup? what kit did you use and did it require soldering or was that your own twist?
Old 08-27-2011, 08:28 PM
This is for the 05-07:
TheDieselStop.Com - www.thedieselstop.com
Old 08-27-2011, 10:40 PM
Although that is not the link I used it is almost identical to what was in the link. The soldering was my own thing, I don't like crimp connectors if I can avoid using them.
Oh and no kit required I had some spare wire laying around the house and a whole mess of heat shrink of various sizes.
Dik
