Puking coolant, Blackstone says not burning it - Ford Powerstroke Diesel Forum
post #1 of 12 Old 08-26-2011, 09:51 AM Thread Starter
Hey guys, I had this issue before with my SRL tune. Every time I take it out and romp on it my degas bottle pukes a bunch of coolant out. Now when I run the 8K tow tune, towing around 10K worth of stuff, driving up and down long steep grades for 16 hours straight.....nothing, no puking or anything. Now I have had this issue for a while whenever I load up Matts SRL, but 8K tow is my daily driver most of the time with no coolant loss at all. Got the updated Bottle cap, and go my Blackstone report saying I have "0!!" coolant in my oil. Now with my experience with other diesel engines, if you have a blown head gasket, you are going to burn coolant. I have absolutely no white smoke on startup after sitting overnight, and no white smoke when getting romped on. What else could this be?
Kobane is offline
post #2 of 12 Old 08-26-2011, 10:00 AM
Do you have an EGR cooler?
HAM_RADIO_MAN is offline
post #3 of 12 Old 08-26-2011, 10:11 AM Thread Starter
yes i do, stock
Kobane is offline
post #4 of 12 Old 08-26-2011, 10:18 AM
Pull the EGR valve out and look inside the manifold for any wetness or goo. Do you know what your eot vs ect delta is? If your oil cooler is plugged up it will starve the EGR cooler for coolant and let it turn into a steam generator. The steam then vents into the degas tank and puking happens. The other fear I have is that the tune that causes the puking is running a lot of extra injection timing and causing high enough cylinder pressures to lift the heads or expose a bad head gasket.
post #5 of 12 Old 08-26-2011, 10:22 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Do what the above poster said. Also pressure test your cooling system
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 12 Old 08-26-2011, 10:24 AM Thread Starter
Delta hasnt gone above 12 DEG F yet (Edge insight CTS), you make a valid point about the high HP tune lifting the heads and causing puking. Going to load the stock tune back up and drive that for a while. Im curious to know, I still have aftermarket warranty, I have CAT - ELC coolant, just wondering if driving around in stock tune for a bit, then take it in to get the truck checked out, will the stock tune burn up any of the "Tuned Spray" pattern you would see on the pistons? That way they cant really trace the hot tune, and if it is the head gaskets, when they pull the heads off they will see the spray and know I have been running tunes and deny me warranty.
Kobane is offline
post #7 of 12 Old 08-26-2011, 10:27 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Spray pattern is the least of your worries with custom tuning.
IM thinking EGR is your issue. But pressure test it anyway.
Email:
Edge Insight CTS
Coolant filter
Dave is offline
post #8 of 12 Old 08-26-2011, 10:37 AM Thread Starter
Thanks for the help guys, im off to bed, spent the night swapping out an oil cooler on a CAT haul truck and am pooped. For now im going back to stock tune, and on days off gonna visit the Ford dealer and have them look at the EGR cooler. Cheers gents!
Kobane is offline
post #9 of 12 Old 08-26-2011, 04:43 PM
PGreenSVT's Avatar
Feedback Score: 3 reviews
The heads aren't going to lift unless you are burning a fair amount of coolant. The TTY head bolts aren't as bad as people make out.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #10 of 12 Old 08-26-2011, 09:40 PM
My thinking was that if his head gaskets were marginal, maybe the extra cylinder pressure from the hot tune was able to expose them as a weak link. I shouldn't have used the language about lifting the heads. You are correct as usual unless the engine is making steam by burning a lot of coolant the heads won't " lift" Thanks for keeping me on track.
