truck ideling funny
On my wayhome from work tonight and stop at light anf my truck is idling weird . Kind of like there was a miss. Could it be a fuel problem?? Maybe fuel filters . Any help would be great
Check your fuel filters or change them with Motorcraft or Racor filters only. Check your FICM voltage. Check your ICP and IPR duty cycle. If they are all good try some Rev-X in your oil.
Ok thanks. How do I check my ficm voltage
thank you. very helpful. will attempt this weekend. also how many fuel filters are there?? one on top of motor and one next to the pump on the rail?? i guess i will just change them as well
Yup. Racor filters from dieselfiltersonline.com
Weird surging or bucking at idle can be a problem with the high pressure oil system.. ICP sensor usually, maybe the wiring to the sensor.
Mine will do the same surge at idle every once in a while after getting off the interstate. Seems like it just dont like to stay at one speed with the cruise set for over 50 miles, cause when I slow down to exit, it will be surging. I can throw it up in neutral and rev it a couple times and it will clear up and idle normal. After that, I can drive stop and go traffic all day with no problem. Just coming out of long drive on cruise on will cause it.
Is this about what yours does or does yours do it during stop and go driving? |
