A question for PowerMax users. - Ford Powerstroke Diesel Forum
Old 08-24-2011, 04:13 PM
I'm wondeing how much lower your EGT's are on average after installing one or if you didn't see any change. Also did you see a change in fuel use better or worse. Thanks for any insight into this.
Old 08-24-2011, 04:25 PM
If you change the compressor wheel out for a Batmowheel it will spool faster, make a bunch more power and run up to 200* cooler.
Old 08-24-2011, 04:36 PM
do you run one?
Old 08-24-2011, 04:47 PM
I saw about a 200* drop at WOT but my truck is also 12k lbs every day.
Now difference in MPG's.
Do the batmowheels help the Powermax also?
Old 08-24-2011, 05:25 PM
Originally Posted by U235a4 View Post
do you run one?
Buying one tomorrow. New shipment due in at 10am.
Yes they have a Batmowheel for the Powermax too. MPD dyno'd a 6.0 Powermax with a Batmowheel and 190cc injectors yesterday. The torque gauge was broken on the dyno but it put down and extra 31rwhp. Based on that I would guesstimate it made around 150rwtq or more over the stock Pmax. The 03 turbo with a Batmowheel and 190's made 11rwhp and about 110rwtq over the stock 03.
Old 08-24-2011, 05:30 PM
interested in this batmowheel, what is it?
my egt dropped about 150 when installing my powermax.
Old 08-24-2011, 06:42 PM
Stock wheel on the right, Batmowheel on the left and below. The stock wheel is cast and the Batmowheel is billet and lighter with a different fin configuration that is more effective at stuffing air into the engine. They are manufactured by Bullseye Power.
Old 08-25-2011, 11:55 PM
Where did you order yours from and you said they make them for the stock turbo?
Old 08-26-2011, 02:19 AM
Almostdunfukinwidit
Yes they make them for the stock turbo. Bullseye turbo is who makes em.
Old 08-26-2011, 05:26 AM
I wonder if they can make a 65/88?
