Coolant filter Q's
Just got the 05 and doing the coolant flush.
I happen to have a remote oil filter set up I never put on my marauder with the mounting block for a spin on filter, fittings and hoses. Instead of purchasing a kit can someone tell me specifically where these are tapped into and out of the coolant system? Mounting suggestions? Filter cartridge type and rating? Thanks! |
Im not sure it the oil filter housing threads and sealing surface. Here is info I have collected over the the past year or so.
size specs Thread Size: 11/16-16 Outer Diameter: 3.66" (93 mm) Gasket OD: 2.81" (71 mm) Gasket ID: 2.42" (61 mm) COOLANT FILTERS Fleetguard WF-2077 no addative Baldwin B5134 no addative John Deere RE11992 no addative Caterpillar 9Y4528 no addative Cummins 3300721 no addative Wix 24070 no addative and 27 micron NAPA 4070 no addative and 27 micron AC-Delco WF-108 can't find any info other than it cross-references Fram PR3383 can't find any info other than it cross-references Donaldson P554685 /ECF4085 no addative 20 micron Alliance (Freightliner) WF2077 can't find any info other than it cross-references CarQuest 89070 can't find any info other than it cross-references |
Very good info, thanks!
Can anyone tell me how it ties in? |
I didnt look at these but this may help.
ford 6.0 coolant filter install - Search.com basically you tap into the heater line and return the bypass thru the overflow hose line. Also look at one of the kits that advertise and they have install instructions normally posted. I believe the T is a 5/8 inch which is reduced to 3/8 to the filter, and 3/8 out just cant remember the sizes but I think I am close. The heater line to tap is the "Z" shaped one going under the heater vacuum control on the passenger side. I am sure others will chime in. |
Thanks for all the replies. The search link showed a youtube video of a sinister step by step install! Perfect!
