Upgrade Injector and Turbo Recommendations - Ford Powerstroke Diesel Forum
Old 08-22-2011, 07:47 AM
My truck hard starts all the time it seems. So I want to upgrade the injectors. While Im doin that may as well do the turbo too. I have arp head studs, egr delete done. One day I will do the tranny but not till next year. What would you guys recommend are good upgrades from stock?
Old 08-22-2011, 07:59 AM
Feedback Score: 3 reviews
The hard start issue may not be injectors. Have you tested your FICM? How about batteries? What year truck? What motor oil? Which fuel/oil filters? Did you pull any codes with a GOOD scan tool?
Old 08-22-2011, 08:40 AM
two brand new batteries. 05 f250
I find sometimes if I turn the truck off say at a drivethrough like mcdonalds. it takes like 30 seconds to start a few minutes later
Old 08-22-2011, 09:37 AM
With the '05 it sounds like a HPOP system leak, not injectors. STC fitting, stand pipes, dummy plugs, or HPOP. classic signs of these is no/hard start when motor is hot.
Old 08-22-2011, 09:47 AM
BurninRubber&BlowinSmoke
Completely agree. Start testing that HPOP system.
Old 08-22-2011, 09:53 AM
Yup, prolly the STC fitting is going. Look into it before spending money on injectors. They are prolly not your problem.
