What's the difference in a f-250 and a f-350srw?
Is it just blocks or is the springs different as well? Thanks
different cab/bed options, rear block, axles are different, I believe they use different spring packs
Axles are the same. The difference is the blocks and the sticker. You can get the same springs depending on the package ordered.
i have never compared or counted however according to Ford and F350 has more axle splines than an F250.
There are a few differences between the F250 and the F350:
1) The Emblems 2) The Front Springs GAWR (4000-5600) actually can be the same depending on options 3) The Rear Springs GAWR are 6100 F250 or 7000 F350 4) GVWR on F250 is 9000 (option to 10,000) and either 10,100 or 11,400 on the F350 5) Rear Axle F250 is rated at 6200 and the F350 is rated at 7280 6) Rear Axle shaft spline minor diameter on F250 is 1.36" and on the F350 is 1.50", the major diameter is 1.50" on the F250 and 1.57" on the F350. Also the splines are 35 on the F250 and 37 on the F350. 7) 2 inch blocks for the F250 vs. 3 3/4 inch blocks for the F350 8) Both have the same 13.66" front rotor and 13.39" rear rotor brakes https://www.fleet.ford.com/truckBBAS...essd-ms_06.pdf |
