6.0 boost pressure .....
I am having a problem building boost pressure. i can't peak over 20-21 psi. i have a few mods as well. here is the list : edge juice w/attitude platinum-hot unlocked, fuel pressure reg. upgrade spring, upgraded banjo bolts, airdog 2 165, upgraded stand and dummy pipes, upgraded stc fitting, egr delete, 5" exhaust, afe stage 2 intake, zoodad mod, water meth. truck 2005 has 92,000 miles. thanks in advance.
any help would be great
Has it always been 20-21psi, or did this happen after certain mods?
Turbo Vanes could be stuck and needing a cleaning.
http://www.forddoctorsdts.com/articl...icle-06-05.php |
Crack in the CAC tubing somewhere?
not that i noticed, i was playin in it the other day and noticed i wasn't makin as much boost as i had in the past (average 25 psi)..... i am leanin towards intake elbow leaking where i tapped for the meth.... but not sure
ok so you mentioned a crack somewhere.... i went out and looked at it, and i found a 1/8" lont crack where i tapped my elbow for the meth. kinda hard to see unless i am on the right angle.. could that be my problem?
I had cracked one of my ports for water/meth on my CFM+ elbow, used a poxy like JB weld to fix the cracked plastic around the brass insert. |
i know my exhaust isn't cracked cause i just had my turbo off to do the stc upgrade and checked it. now it may be my IC boot on the turbo, its been on and off quite a few times ( i will check it.) i have been thinkin bout replacing my intake elbow anyway... lookin at the s&b it has the ports and high flow rate.
The only thing your gaining on a aftermarket elbow is the tapped ports, your not gaining any more air/flow, the main restriction is the intake manifold and ports of the heads. You might as well stick with a stock elbow, unless you like wasting money and want a fancy one. |
