Does someone know what the upgraded turbo supply tube look like?
I bought what I though was the updated turbo oil supply tube.
It's a solid tube. The one I took out has a flex section in it. I bought the truck new in 2006, so I know this has not been replaced (unless the dealer did this without telling me; I did take the truck in a couple of times, but never for anything related to the turbo). Just wanted make sure I put back the best one. There might be pro's and con's to using each. I would think the flex section might have an advantage in the sense that it would put less pressure on the connection to the turbo....maybe even withstand a little more vibration. But, I really don't know whether the flexible or solid one is the best. Can someone give me some help? Which one works the best? |
The solid one is best.
Don't panic,you did good because the flex could cause a restriction and reduce oil supply to the turbo.
the solid is the updated one. |
Thanks, NYC F-350 and 05harley,
Not in a panic...just want to make absolutely sure I put in the latest and greatest parts. And thanks, again! |
