Coolant Degas Bleed down time? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-20-2011, 05:35 AM Thread Starter
Just a weird question after my truck sat all night i cracked the degas bottle cap and there was no pressure on it? I swear a few weeks ago it held pressure all night. Am i just worrying about nothing? FYI i did the ELC coolant flush last weekend as well.
My delta's are in check and no coolant loss. Just curious if it should hold pressure or if i possibley have a loose hose clamp causing it? No leaks that i can see
Thanks
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
SCT tuned by Innovative
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
6.4 Banjo's Blue Fuel Spring
ELC Coolant/Sinister Filter
yarmish is offline
post #2 of 7 Old 08-20-2011, 08:01 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Might need a new cap.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 7 Old 08-20-2011, 08:25 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
^^^^ agree. Here is a picture of old and new caps. Old on the left.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #4 of 7 Old 08-20-2011, 11:00 AM
buc1096's Avatar
Feedback Score: 3 reviews
I replaced my degas bottle last year when it was leaking from small cracks on the bottom. I didn't change my cap, but now that I see the pics I definitely have the old cap with white label.
Try changing the cap, there not very much $ and see it that works.
2005 F-350 6.0 PSD
20" XD's, Straight 4" "Kittyless" exhaust, Pioneer Nav/DVD w/ 4 monitors and PS3,
buc1096 is offline
post #5 of 7 Old 08-20-2011, 04:50 PM Thread Starter
I checked and i do have the new degass cap,I also found where the spring clamp on my upper house wasnt as tight as i think it should be,When you squeezed the hose you could see a small spot of coolant bulge out. I replaced that clamp with a regualr hose clamp and tightened her down. I also put about 100 miles on my truck today and some of which was pretty tough with the ac on and 90 degree temps. My degas bottle was down about 1/4" from what it was this am. No leakes to be seen anywhere,Truck runs great and the oil is clean. I am thinking i am still burping some air out from last weeks ELC coolant swap? Sound like a legitimate reason? I have put maybe 150 miles on since the flush with 100 of that being today
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
yarmish is offline
post #6 of 7 Old 08-20-2011, 06:07 PM
Quoted: 4 Post(s)
This probably goes with out saying, But just for fun, the fill mark is the bottom mark on the degas, not the top one. And leave it just a tad lower than that bottom line.
And yes you could have had a lower level due to the coolant change. You should have it balanced out now.
post #7 of 7 Old 08-20-2011, 06:13 PM Thread Starter
Thank you and yes i have been using the lower line for the fill. Since i have had the truck it likes the coolant to sit about a 1/2" below that line. It never moved before i did the flush and added the Sinister Coolant filter so hopefully it levels out now. I am doing the new oil cooler/EGR Delete on monday as well as the fuel spring and Banjo's so i hope i can take some time and just enjoy the truck for a bit after that
2004 F-350
Edge Insight CTS
4"MBRP Cat Delete
ARP Head Studs
03 Turbo
Leveled on 35's
Sinister EGR Delete
yarmish is offline
