Determinung my Gear Ratio.
2005 F-350 6.0 DRW Lariat 4X4 FX4. Im really trying to find out what gear ratio i have. Driving on the Highway at 70mph im at around 2300 rpm give or take. The is no owners manual. How do i get this info? Thanks in advance.
There is a tag on the rearend.
If you look on the dif cover there should be a small tag on one of the bolts and on it you will find the ratio. Both axles will/should have a tag
Just looked at the tag on the rear and it says 4.30. DAMN, i should have looked at it when i bought the truck, considering its my daily driver doing mostly commutes to work and back. I will only be towing a car trailer once in a blue moon. So what tire size should i shop for to lower the ratio down some? It has 235/80/17 right now and they only have like 30% left.
I'll swap for the 4:30's. I need bigger gears. Buffalo you beat me to it.
I could use those 4.30s too now that I put the 22.5s on.
Both our trucks are 05 DRWs ![]()
That does sound about what I have doing 70 mph, and I have the 4.30's.
That tire size isn't what I have though, mine are 245/75R17E. Going a little taller might help, but if you do a gear swap you'll never get your money out of it. This truck is my daily driver, there is a few things you can do to help mileage. Tuner, exhaust, and keep your foot out of it. |
