Just bought one... - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-17-2011, 10:04 PM Thread Starter
Country Mav's Avatar
Quoted: 2 Post(s)
Just bought one...
Hello all- I bought a 2005 F-250 CC FX4 a couple of weeks ago. 84,000 miles on the 6.0/Auto and the carfax showed that it was serviced at the dealership up until 71,000 miles. That made me feel a little more comfortable about buying the truck. I had a 2003 F-450 work truck that was in the shop more than it was on the road with EGR, oil cooler and other problems. However, that being said, I got a really good deal on this truck and I'm hoping and praying that it'll be as good to me as all of my other Fords (except the F-450) have been through the years. I have a few questions though. Whats the issue that some have with a certain type of coolant? And how can I tell if my truck has an EGR delete already installed? I put a Superchips Cortex on a week ago- mainly to try to get the fuel mileage up. When I checked the DTC codes, it shows 2. PO403 and PO405. Does this mean the EGR has been turned off? What are a few things that you guys could reccomend doing asap to help ensure that this thing lives a long time? I'm loving the truck so far! Thanks in advance!! Sorry it was so long!
Preston
PS- I probably won't be staying with the Cortex. I know that the general consensus is that the custom tunes are the way to go and I may go that route. So far the truck only has a muffler delete and the programmer. I'm not looking to break any land speed records- but I do pull a lot on the farm and I haul a lot of my FFA kids ( I teach high school agriculture) so I'm mainly looking for fuel economy and towing. I will say this though, this thing will SCOOT with just the cortex performance tune...
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #2 of 14 Old 08-17-2011, 10:22 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The first thing should be aftermarket monitoring system like the Edge Insight CS/CTS or the ScangaugeII. Add in a fuel psi gauge and EGT gauge.
Read this link for info.
Things to consider about owning a 6.0L
I don't think the Cortex is capable of turning off the EGR. Either you have a gummed up EGR valve, or the EGR valve is unplugged electrically (not recommended), or you have a delete/welded EGR cooler.
You can look on the pass side of the motor, between the turbo and valve cover, under the intake manifold. There will be either a blue or orange short hose, this hose goes from the oil cooler to the EGR cooler. Follow the hose toward the back of the motor, it connects to a metal tube. If the metal tube does a complete U-turn and heads back toward the front of the motor, then it's a delete. If the metal tube stops at the U-turn, it's got the EGR cooler.
You will see the yellow "X", the first picture is a delete. The second picture is where the tube goes to the EGR cooler.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 14 Old 08-19-2011, 09:06 AM Thread Starter
Quoted: 2 Post(s)
Thanks for the good information! I appreciate it! I'm sure I'll have many questions before it's all said and done... Preston
Sinister EGR Delete
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
EGR Delete
FARM TRUCK
post #4 of 14 Old 08-21-2011, 03:39 PM Thread Starter
Quoted: 2 Post(s)
Will the Edge measure fuel pressure?
Sinister EGR Delete
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
EGR Delete
FARM TRUCK
post #5 of 14 Old 08-21-2011, 04:10 PM
Powerstroke Techie
Lilpooh's Avatar
Only the new ones (CS/CTS), and it cost extra for the cable.
Lilpooh is offline
post #6 of 14 Old 08-21-2011, 07:17 PM Thread Starter
Quoted: 2 Post(s)
Sinister EGR Delete
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
EGR Delete
FARM TRUCK
post #7 of 14 Old 08-21-2011, 08:44 PM
Powerstroke Techie
Lilpooh's Avatar
So, is this an EGR delete? Attachment 27982
Yes, that is a EGR delete.
Lilpooh is offline
post #8 of 14 Old 08-21-2011, 10:35 PM Thread Starter
Quoted: 2 Post(s)
Perfect! I'm sorry for the basic questions here. Generally, I'm above the average when it comes to mechanical inclination.... But I'm nervous on this truck. I don't want to miss anything important. I really appreciate your help. Since I do have an EGR delete, is there anything else I need to worry about? I mean, do I need to flush anything, or do anything else with the EGR? Thanks a lot! Preston
Sinister EGR Delete
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
EGR Delete
FARM TRUCK
post #9 of 14 Old 08-22-2011, 04:19 AM
If you're still running Ford Gold Coolant, it is highly advised to flush that out and put in a coolant that will not clog up your oil cooler. Since you don't have an EGR Cooler anymore, that simply means that the EGR Cooler will not be the first point of failure if your oil cooler gets clogged. Instead, the oil cooler itself could fail, either by not cooling your oil sufficiently, or in the worst case, physical failure.
The EGR Cooler leaking is a symptom, not a problem in and of itself. You've prevented the symptom from occuring, but fixing the actual problem is changing the coolant.
No Power? No Boost? Check/Clean your EGR VALVE!
2006 F350 SWR Lariat
-EGR Delete
-Evans NPG+ Waterless Coolant
-ZERO Pressure Coolant system
-Dieselsite Coolant Filter
-Mini Maxx Monitor/Tuner
-Blue Spring
Dicion is offline
post #10 of 14 Old 08-22-2011, 06:14 AM Thread Starter
Quoted: 2 Post(s)
So, I just need to do a good Coolant Flush? Then refill with the CAT coolant? I really appreciate it y'all!
Sinister EGR Delete
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
EGR Delete
FARM TRUCK
