2006 6.0 Power steering/Brakes - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-13-2011, 07:24 AM Thread Starter
xXHDSTROKEXx's Avatar
Hey guys have a question. Driving my truck last night (2006 F250 Powerstroke) when I was pulling into my drive way applying brakes everything felt weird and very hard to steer. The next day brakes seemed ok they do feel odd sometimes like a vibration feeling in the pedal but i do not have power steering at idle or very low rpms. PS pump is not making any noises, i have no leaks and fluids are full...So brakes feel odd sometimes driving, no power steering at low rpms fine while driving... Any ideas? Please help... thanks again guys..
2006 Harley Davidson F250 Powerstroke #01311--
K&N Intake, MBRP 5" Black Exhaust, 4" Down Pipe, SCT tuned, Semi Blacked Out, Recons Lens and Lights, APR Studded, OEM Gaskets, EGR Delete and soon Coolant Filters....
2004 Mach 1 Dark Shadow Grey 5 speed
xXHDSTROKEXx is offline
post #2 of 6 Old 08-13-2011, 08:24 AM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 116 Post(s)
Feedback Score: 3 reviews
IIRC the brake booster and PS booster share the same pressure (somewhat). When doing both at times there is a los of feeling in the steering. I don't understand the full nature of this issue but it's not uncommon. Sometimes it's scary.......
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #3 of 6 Old 08-13-2011, 08:32 AM Thread Starter
so what do you think my problem is now?
post #4 of 6 Old 08-13-2011, 08:47 AM
N.S.D.Q.
Quoted: 116 Post(s)
As far as the PS is concerned I think it's the nature of the beast. Wish I understood the system better to explain the issue better.
For the brakes it could be you are just more aware of what's going on. Best test I use for the brakes is on a road that the truck will track fairly straight and true without needing any steering wheel input. Then at a speed up to 55MPH I just apply the brakes in a firm manner. As long as the truck stays driving straight while braking that solves any issue were one brake is not applying properly.
For pulsing I pull the tires and check the disc/pads. Any grooves, gouges, warping or other visual/felt problem can cause issues. Without being an expert you can replace parts or just live with it till you get it fixed. Maybe flushing the fluid could help.
post #5 of 6 Old 08-13-2011, 01:39 PM
billingf09's Avatar
My truck did the exact same thing and two days later my power steering pump went out completely and had to replace it, after i installed the new pump everything was back to normal. Hope this helps
2005 F250 6.0
6 inch lift, sinister egr delete, bds oil cooler, afe intake, 37x13.5x18 pro comp at's, dual 6 inch stacks, sct tuned
billingf09 is offline
post #6 of 6 Old 02-21-2014, 06:31 AM
I know this is a old post but I've went through 4 powersteering pumps within a year no hard driving or anything rough on the truck. Does anyone know what might be cause these pumps to keep failing. I'm getting tired of replacing them
Gibbons06 is offline
