Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 08-15-2007, 11:37 AM
pgaigh pgaigh is offline
what do you guess think of this oasis report
it is for an '04 Excursion, I purchased it 2 weeks ago today so I know it is a alittle late to be asking but did I do ok on it.
Also I am very new to the forum, this is my first post. and as a new diesel owner you guys have been helpful already.
thanks
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 0 6Y05 000001 * TDRIVE * A96 82 2
AWS Claim Key: 269194 Trx Code: R7U Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07965 - * Name: CRONIN FORD, INC. Ph: 513-3675300 St:OH Ctry Cd: USA Reg Cd: NA Repr Date:31-DEC-2003 Doc #:067024B Cust Comments: ADD TIME FOR TEST DRIVE Tech Comments: TEST DROVE PER INSTRUCTIONS
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 5C01 050101 3C7Z 4602 AA N24 42 24928
AWS Claim Key: 7223902 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:00580901 Cust Comments: VIBRATION 20 70 MPH, GOES AWAY WHEN LET OFF PEDAL Tech Comments: ROADTEST AND INSPECT, REPLACE DRIVESHAFT
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 1D01 03XXXX 3C3Z 6701 AA L65 D8 24928
AWS Claim Key: 7223903 Trx Code: E84 Labor Hrs: 9.4
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:00580904 Cust Comments: CHECK FOR OIL LEAKING Tech Comments: DYE TEST FOR OIL LEAK, LEAKING AT REAR ENGINE COVER AND GLOW PLUG HARNESSES, LEFT AND RIGHT, R&R TRANS & REPLACE ENGINE COVER SEAL AND MAIN SEAL, R&R GLOW PLUG HARNESSES LEFT AND RIGHT, MTIME TO REPLACE COVER SEAL, MTIME TO REPLACE HARNESSES
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 2A01 031201 5C3Z 9N622 A G29 42 24928
AWS Claim Key: 7223904 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:00580905 Cust Comments: AIR FILTER LIGHT ON AND JUST REPLACED AIR FILTER Tech Comments: INSPECT AND REPLACE INDICATOR
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 2H01 * * * * * * 24928
AWS Claim Key: 7223905 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:00580906 Cust Comments: SERVICE RECALL PROGRAM 05B29 Tech Comments: PERFORM RECALL 05B29, CHARGE AIR COOLER DUCT REPLACEMENT
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 * * * * * * * 24928
AWS Claim Key: 7223906 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:00580907 Cust Comments: SERVICE RECALL PROGRAM 05S34 Tech Comments: PERFORM RECALL 05S34, FICM WIRING HARNESS REPAIR
AWS Claim Key: 7223907 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:26-SEP-2005 Doc #:00580908 Cust Comments: SERVICE RECALL PROGRAM 05E15 Tech Comments: PERFORM RECALL 05E15, REPLACE EP SENSOR, EP CONNECTOR AND RECALIBRATE
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 7M01 150101 * 18806 * A16 42 24928
AWS Claim Key: 7818246 Trx Code: E83 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2005 Doc #:00616401 Cust Comments: CD PLAYER INOP Tech Comments: INSPECT CD PLAYER, REMOVE FOR REPAIRS AND INSTALL AFTER REPAIRS
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 16 7M01 150101 3C7T 18C815 AC A07 42 24928
AWS Claim Key: 9154889 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:06-OCT-2005 Doc #:99230400 Tech Comments: REQUESTING DEALER'S P/A CODE 02743
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 18 6R01 011001 1C3Z 78613D98 AAA S25 42 28839
AWS Claim Key: 7940205 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2005 Doc #:00784801 Cust Comments: CHECK PASSENGER SIDE CENTER SEAT BELT WONT LATCH Tech Comments: INSPECT AND REPLACE LATCH ON PASSENGER SIDE MIDDLE ROW SEAT, RETEST
1FMSU43P14EB97696 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 23-DEC-2003 25-JUN-2004 148419 USA 18 5A06 050204 F81Z 4947 AA K02 42 28839
AWS Claim Key: 7940206 Trx Code: E84 Labor Hrs: 3.2
Dlr Cd-Sub Cd: 02743 - * Name: BILL MACDONALD FORD, INC. Ph: 810-3296601 St:MI Ctry Cd: USA Reg Cd: NA Repr Date:12-DEC-2005 Doc #:00784802 Cust Comments: CHECK FOR CLUNK WHEN JUST TAKING OFF AFTER BACKING UP Tech Comments: ROADTEST AND INSPECT FOR AXLE NOISE, CHECK BACKLASH .011 WITHIN SPECS, DIAG, PACK ASSY, R&R AND REAR AXLE AND RETEST
Old 08-15-2007, 11:42 AM
blairian blairian is offline
there was some pretty major engine work and drivetrain work on that truck..but she should be good to go
