6.0 Normal coolant temp - Ford Powerstroke Diesel Forum
post #1 of 23 Old 07-25-2011, 06:19 PM Thread Starter
Brian82's Avatar
What temps are you guys seeing for normal driving unloaded for coolant temp. ?
Also i thought i read on here some where greater than 15 degrees separation EOT vs Coolant temp is an issue, I have also read a Ford service bulletin stating up to 25 degrees separation is acceptable. ?
06 F250 6.0 Powerstroke-me Egr delete, cat delete, muffler delete, scanguage II, SCT Flash Tuner. Coolant delete?
Brian82 is offline
post #2 of 23 Old 07-25-2011, 06:41 PM
Galaxie's Avatar
At normal operating temp, you dont want your oil 15* above your coolant under normal driving. This is only after it is at normal operating temp. Driving in 90* weather I am right around 195* to 205*.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #3 of 23 Old 07-25-2011, 06:42 PM
jetjock15's Avatar
Quoted: 113 Post(s)
use search feature, many posts on this topic.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #4 of 23 Old 07-25-2011, 06:51 PM
Quoted: 58 Post(s)
Thermostat begins to open at 193 to 195F. My unloaded ECT at cruising speed ranges from 192 to 205F, with EOT generally 8 to 10 degrees higher. If you have the latest PCM flash it should throw a code when EOT exceeds ECT by >25F.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 23 Old 07-26-2011, 03:44 AM
Davey~do's Avatar
202/207 in 85-90 temps unloaded. 210/215 when it's over 100. Mine seems to want to run hotter than most folks on here fess up to.
David
2016 CCSB SRW FX4
Davey~do is offline
post #6 of 23 Old 07-26-2011, 07:22 AM
The most i have seen so far is 196 degrees. Thats with the a/c on and 90+ degrees out in the hot florida sun. Its so damn hot down here!!!!! Slap me next time I complain about the cold weather!
2005 F250 Lariat crew cab 6.0L 4X4 6 Airaid filter,
Arizona beige over black 3 inch exhaust(no cat)
High idle mod
Edge insight cs Dieselsite coolant filter Zerex CAT1 ELC LOVING MY TRUCK!!!!
More to come.....
dragrazor is offline
post #7 of 23 Old 07-26-2011, 11:31 AM
SVO Ryan's Avatar
187-195 here.
Ryan
'06 F250 PSD Crew Cab
- Gearhead Tuned, Studded, CFM Elbow, MBRP 4" TurboBack Exhaust, Edge Insight CS, ISSPRO Gauges (Boost, HPOP, Fuel Pressure), Blue FPR Spring, Sinister Coolant Filter
SVO Ryan is offline
post #8 of 23 Old 07-26-2011, 02:09 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 115 Post(s)
Feedback Score: 3 reviews
BS!!
The 15* delta per the Ford TSB is under HEAVY LOAD/FULL THROTTLE. Stop the madness!!
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 23 Old 07-26-2011, 03:02 PM Thread Starter
Brian82's Avatar
Well.... ok. i guess i have me a clogged oil cooler than. i run around 18-22 degrees above my ECT. I thought i read up to 25 was good, but im guessing thats not the case. i would need to flush that ford crap out, then replace the oil cooler im thinking would be the best way about it
Brian82 is offline
post #10 of 23 Old 07-26-2011, 03:07 PM
dieselburner21's Avatar
Quoted: 8 Post(s)
195-205 here also but my rot is never more than 8 higher
Will
2010 FORD F250 LARIAT CCSB 6.4
-H&S Mini Maxx / Edge Insight CTS / 4" Flo Pro Dump / 20" Fuel Hostages / 33" Toyo AT's / Airdog II 4G
2006 FORD F250 LARIAT CCSB 6.0 - TRADED
2000 FORD F250 LARIAT CCSB 7.3 - SOLD
dieselburner21 is offline
