Oil temps normal? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-18-2011, 06:53 PM Thread Starter
Oil temps normal?
I am alittle confused with my oil temp and maybe someone can help? I have an 05 f250 I have an edge set to zero and only use it to monitor my temps ( egt,eot,ect,trans temp) this truck was updated with the latest flash from ford Jan 2011. I also have a custom Sct turn on the truck now here's where I am confused, my oil temp has climbed as high as 214 intown not towing and on the highway but I have also seen it drop way off well under 175 while driving the ect is always around 192 to 196 so if my oil temp is over 15 deg delta shouldn't the truck be throwing a code and wrench light on the dash because of the 15 deg over delta?
zman111 is offline
post #2 of 10 Old 07-18-2011, 07:01 PM
Galaxie's Avatar
Wait, so it has got to operating temp but then dropped down to 175? Like it was at 190-200 then dropped back down and the coolant was still at normal temp? Something is off.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #3 of 10 Old 07-18-2011, 07:03 PM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
you will notthrow a code at 15 degrees difference. I think ford has the truck defuel if eot reach 250. do you have an egr delete? what other mods do you have. Over 15 degee difference between ect and eot usually is an indication your oil cooler is shot
Mike
"The Iron Pig"
mudrunninpig is offline
post #4 of 10 Old 07-18-2011, 07:04 PM Thread Starter
Yeah it will be at 214 the start to drop the go back up. But I never get a light for being over 15 deg even though it is.
zman111 is offline
post #5 of 10 Old 07-18-2011, 07:06 PM Thread Starter
It was my understanding that the newer flash ford has will trigger a light if your oil temp is over 15 deg delta? Truck still has the egr. But does have custom tunes from gearhead.
zman111 is offline
post #6 of 10 Old 07-18-2011, 07:14 PM
Zander's 5.8's Avatar
I think that was part of the new re-flash on the 6.4's but i could be wrong.
03 F-250 7.3L, Sport, 4x4, Auto
Zander's 5.8 is offline
post #7 of 10 Old 07-19-2011, 03:31 AM
Quoted: 6 Post(s)
Ford issued a TSB for a flash update that is for the 05 and up year models that will throw the wrench light and a P012F code for oil cooler effieciency if the oil cooler is plugging up. That efficiency code is based on a 15 degree delta temp (EOT/ECT), but is based on a number of operational factors (coolant temp above 189 IIRC, 65 mph, probably some others).
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #8 of 10 Old 07-19-2011, 07:02 AM
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Engine load is monitored as well, but I don't remember what the threshold is.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #9 of 10 Old 07-19-2011, 07:04 AM
Quoted: 5 Post(s)
Yep sounds about right, but I heard that they changed it from 15* to 25*? Not sure about that.. Just had one that had a wrench light on, PO12F code and the highest spread I could get was 23*. Also I cleard the light, then drove it for about 50 miles and could not get it to come back on, even after many key cycles and 23* of spread.
a2elvis is offline
post #10 of 10 Old 07-19-2011, 09:44 AM Thread Starter
Yeah this is why I am not sure if maybe the sensor is bad? If I am crusing the highway at 65 and my ect is 192 and my eot is 215 hat would be a 23 deg spread and I should get a light on the dash but the very fact that my eot will be at 215 then start to lower it's self down to around 170's and then jump it's way back up to the 200's makes me think he sensor is bad? Maybe it's not really at 215 I don't know, I thought when they go bad they never climb in temp?
zman111 is offline
