single or dual alternators ? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 07-14-2011, 03:48 PM Thread Starter
this may be a stupid question but , does the 6.0 have one or two alt's on it ? I was checking on advance's site and they had more dual applications than single for alt. replacement. ????
06 f350 super cab dually SOLD.
02 f350 ext. cab Lariat . 6637,edge insight cts,plenum inserts, riff raff boots ,diy ccv delete, IH up-pipes
walleyecat is offline
post #2 of 17 Old 07-14-2011, 03:53 PM
I believe only ambulance packages had dual alts.
Austin G is offline
post #3 of 17 Old 07-14-2011, 04:01 PM
Mine has dual alternators and its not an ambulance. I think that it was ordered that way and whoever ordered it backed out of the deal for some reason. I have not seen too many dual alternator trucks out there though. What are the benefits of having two alternators anyways?
2005 F250 Lariat crew cab 6.0L 4X4 6 Airaid filter,
Arizona beige over black 3 inch exhaust(no cat)
High idle mod
Edge insight cs Dieselsite coolant filter Zerex CAT1 ELC LOVING MY TRUCK!!!!
More to come.....
dragrazor is offline
post #4 of 17 Old 07-14-2011, 05:18 PM
rem1981's Avatar
Because ambulances, work truck applications, and various other uses put a huge demand on the electrical system. Think about all of the equipment running on an ambulance. All of the truck's vitals, plus, a ton of flashing lights, overhead lights for the EMT's, a whole bunch of medical equipment...that kills a electrical system fast. On a work truck you might be running a welder, generators, stuff like that.
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #5 of 17 Old 07-14-2011, 05:35 PM
Not to be a smart A** , but look under the hood the alternator is the only thing driven by the belt that has it’s own fan. Some have 1 others have 2
HAM_RADIO_MAN is offline
post #6 of 17 Old 07-15-2011, 06:01 PM
Quoted: 57 Post(s)
Mine has two. Was ordered that way by the previous owner.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #7 of 17 Old 09-06-2011, 04:45 PM
Flatbedstroker's Avatar
So i kno my truck has dual alternators on it but i was curious if u had to have an ambulance package to get the duals? And second question is what kind of amps does each put out at idol and at max output? I kno they are stock?
Flatbedstroker is offline
post #8 of 17 Old 09-06-2011, 05:36 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
I have dual alternators also, but couldn't tell you why some came with single or dual, never really wanted to know!LOL!!!
Here is a copy/paste from another site I'm on.
The charging system is a negative ground system consisting of the following:
- generator(s)
- internal voltage regulator
- charging system warning indicator
- storage battery
- necessary wiring and cables
Generator
The generator is belt-driven by the engine accessory drive system.
The single generator system consists of the generator mounted on the top right of the engine (diesel) or top center of the engine (gas). The gas
engines use a 3G 115-amp generator with a 2.71:1 pulley ratio. The 6.0L diesel engine uses a 6G 110-amp generator with a 2.79:1 pulley ratio.
The dual generator package consists of an upper/lower dual generator system. The 6.0L upper generator is a VR42 140-amp generator with a 2.79:1
pulley ratio. The 6.0L lower generator is a 4G 120-amp generator with a 3.00:1 pulley ratio. The upper and lower generators are not interchangeable.
In the single generator system, with the key in the ON position, voltage is supplied through the instrument cluster warning indicator I circuit to the
voltage regulator. The regulator grounds this circuit and the charging system warning indicator is illuminated. When the engine is started, the
regulator removes the ground on this circuit and the warning indicator turns off.
On the dual generator system, the PCM controls the charging system warning indicator and commands the lamp on if the PCM detects a concern on
the monitored circuits.
The dual generator system is also monitored and controlled by the PCM. The PCM monitors both the upper and lower generator I circuits to
determine the output of both generators and sets possible diagnostic trouble codes (DTCs). The PCM controls the lower generator by turning it off
when the glow plug system is commanded on by the PCM to avoid possible damage (excessive voltage) to the glow plugs. As soon as the glow plug
system stops cycling, the PCM powers up the lower generator.
The dual generators operate independently of each other. The control is through the internal voltage regulators. If one generator fails, the other
generator can maintain system performance under light load conditions. Under a heavy load, the PCM detects a concern, sets a DTC, and illuminates
the warning indicator.
The set voltage varies with temperature and is typically higher in cold temperatures than in warm temperatures. This allows for better battery
recharge in the winter and reduces the chance of overcharging in the summer.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 17 Old 09-06-2011, 05:54 PM
Ranger429's Avatar
Dual alternators was an option, I ordered it on my truck. I specifically got it because I knew I would be plowing and running back up lights, strobes and a rotating light.
I also ordered manual shift transfer case instead of that electronic crap. That is one thing you don't see to often and I don't even think it is available to be ordered that way on a new truck.
Ranger429 is offline
post #10 of 17 Old 09-06-2011, 06:02 PM
Ya i dont think so either, in my expeience tho its the auto part of the vaccum hubs that usually fails not the electroshift. Thank god fords have the manual lock also! Especially for people pushing snow.
Sent from my Autoguide iPad app
