Finally getting it fixed!!
I'm finally dropping my truck off to get fixed.
On the list is: RCD EGR Delete New Oil cooler STC Fitting Dummy Plugs FPR Blue Spring 6.4 Banjo Bolts Ford Head gaskets ARP Headstuds And steam cleaning intake and clean turbo I haven't been able to drive my truck in months. It crapped out one week exactly after I dropped $$$ on the new wheels and tires. Isn't that always the way! |
That's exactly why the first mod anyone should do with these trucks is a good engine monitoring solution. As you found out, it is not an option. |
Had I found this website before the wheels I would have known. Lesson learned.
Insight CTS will be ordered as soon as I get it back |
It really sucks looking out into the driveway and my truck is not there.
I know how ya feel man. I won't get mine back for another 1.5 weeks
Thats about how long before I get mine back.
if you need a tech to work on 6.0's a friend of mine has a shop that has real quick turnaround, and hes very reasonably priced. PM me if you want his contact info he's got room in the shop right now
sounds like you're getting the works. should run great when it's done
new standpipes should come with the headgasket kit, make sure they put them in there too, they'll be updated with the white teflon seals under the top D-ring and they'll have revised check valves |
I'm getting exactly the same stuff done to mine also, except I'm getting some new heads put on too. Can't wait to see how it runs!
