EGR Delete. Way to tell? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-11-2011, 07:38 AM Thread Starter
Acidsniper's Avatar
So I was doing some tinkering under the hood this weekend (cleaning up the POs shoddy wiring job ) and noticed on top of the EGR cooler theres a 5 / 10 written on it in grease pen. I'm assuming that correlates to it having been replaced at that time. The OASIS report showed up clean on the truck and there was no records of it having been done at the dealership or in any of the paperwork I have for the truck.
Is there a way to tell if it's an aftermarket delete / cooler setup without having to actually tear it out? I'm wanting to toss in a BPD Delete setup but going to save the coin if there's already one installed. The truck still has the stock EGR valve in place and plugged in with no CELs. I have yet to pull the EGR valve itself and see if it's clean / sooty / wet.
Coming off the pipe from the Oil cooler is a blue hose boot which from what I can gather is rather common for both stock and aftermarket setups. Based on the pictures I've been able to find the overall setup / dimensions of the stock and aftermarkets look the same from the outside.
So, is there any way to tell if my truck has an aftermarket cooler / delete installed without removing the EGR cooler?
~JW aka "Acidsniper"
2006 King Ranch CCSB FX4
MBRP 5" Turbo Back
DC Power 270 Amp Alternator
Airaid CAI
Edge CTS
Bushwackers
Recon mirror lenses
Dieselsite Coolant Filter
T6 & Rev-X
Proud Navy Vet
Acidsniper is offline
post #2 of 5 Old 07-11-2011, 08:28 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
There is no easy way to tell if it is a sneaky delete unfortunately. You could loosen the bottom of the passenger up pipe and blow compressed air into the scoop and see if it comes out where the egr valve goes but I don't know that it's worth the effort.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 5 Old 07-11-2011, 08:48 AM
Without a tuner, my truck is throwing a CEL with the egr cooler deleted and the valve still plugged in.
06 CC SB FX4 Lariat
ARP Head Studs
SCT X3 Tuned by Vivian (Looney Wild)
Edge CTS
EGR Delete
AFE Stage 1
6.4 Banjo Fuel Bolts
Upgraded FPR w/Blue Spring
Zoo Dad Mod
Sinister Coolant Filter
IDP FICM Tune (Inductive Heat & Performance Tune)
PowerMax Turbo
Cat & Muffler Delete
CFM Intake Elbow
AFE Cold Side Intercooler Pipe
justin99 is offline
post #4 of 5 Old 07-11-2011, 09:34 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Yep. Me too. You have an 06 and that is what they do. Have to have that tuner and the tune to get rid of it.
Acidsniper: And that right there tells me that you don't have the "sneaky" delete. The 06 will throw the infamous P0401 "insufficient egr flow" code.
Please
You could save the life of a sick child
NYC F-350 is offline
post #5 of 5 Old 07-11-2011, 09:39 AM
Correct, ordered my SCT Sat.
06 CC SB FX4 Lariat
ARP Head Studs
Edge CTS
EGR Delete
AFE Stage 1
Zoo Dad Mod
PowerMax Turbo
CFM Intake Elbow
justin99 is offline
