battery symbol light - Ford Powerstroke Diesel Forum
Old 07-09-2011, 05:38 PM
on the instrument panel is coming on sometimes .Owners manual says it means it is not charging properly. Anyone ever have this problem ? Should I be prepared to buy an alternator or could it just be a loose battery cable ?
Old 07-09-2011, 05:44 PM
The Tamed Racing Driver
99% of the time it your alternator going up, but you definatly should go through and make sure everythings tight, especially the batt. cables and the alternator connections.
Old 07-09-2011, 06:25 PM
Do it ASAP so you don't have to spend cash on an alternator and then an FICM. Have your bateries Load tested too.
Old 07-10-2011, 04:22 AM
I just had my dealer test my batteries and alternator at the same time. I ended up having 2 failed batteries.
Old 07-10-2011, 08:51 AM
I'm gonna guess its an alternator. Pull it and have it checked i'll bet its failing...
--DONT buy autozone or oreilly's. Buy a quality alt or it will leave you stranded..
Old 07-10-2011, 09:22 AM
I'll get it tested. thanks for all the info..
