low voltage reading - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-07-2011, 08:13 PM Thread Starter
low voltage reading
when i start my truck up the battery voltage on my cts shows about 12.4 after about 30 seconds i belive the glow plugs turn off the voltage goes up to about 13.4 to 13.6. Then after about 10 to 15 mins of driving the cts shows it about 13.2 to 12.9. I replace the batteries about 10 months ago and then replace them a couple of days ago with the same readings. Is this normal or is something going south on me
mastaking is offline
post #2 of 4 Old 07-08-2011, 03:15 AM
My stock alt vlts are the same but mine will stay around 13.2 - 13.8 after running it for over 10 min. Mine is normal for a stock alt from what ive read.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
New UCF Heads ported & Oringed
Blue fuel spring
sinister coolant filter
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
EGT/ fuel/ oil psi gauges
Bilsteins Shocks
08+ Aluminum Axle Cover
08+ Trans Pan W/Filter
MTW stage 2 DD solenoid
24+ years Ford Employee
SharkDiver is offline
post #3 of 4 Old 07-08-2011, 06:52 PM Thread Starter
whats wierd when i check it at the battery the voltage is 13.73 i would think it would be more like in the 14. I was just wondering if something about to go wrong
post #4 of 4 Old 07-09-2011, 04:29 AM
I thought it should charge to 14v but with the stock alt only getting too 13.6 is normal. When you are not charging past 13.0v I would then start to worry.
05 CC SB 6.0 FX4
SCT w/ SPD
Gryphon Tuned
ARPs
Blue fuel spring
Egr Delete
5" DiamondEye TBE
BFG ATs 35s
ELC Cat-1
Scangauge
Bilsteins Shocks
