Can I Fit 35s? - Ford Powerstroke Diesel Forum
Old 07-07-2011, 07:31 AM
Can I Fit 35s?
I have a 2005 F250 4x4 FX4 with a 2.5" Leveling kit. I was wanting to know if anybody has any idea if a set of MasterCraft 35x12.5R17 CTs on a set of Mickey Thompson Side Biters will fit?
Old 07-07-2011, 07:33 AM
Unapologetically American
Feedback Score: 4 reviews
Yes, they will fit, depending on the backspacing of the wheels, they will not rub. Mine don't on my 350
Old 07-07-2011, 07:34 AM
back spacing has a lot to do with what will fit. yes i have done 35's on the trucks with a leveling kit. May need to pull the fenderwell back at the bottom a bit
Old 07-07-2011, 08:03 AM
As mentioned wheel back spacing has a lot to do with it. In general tho, a 35 x 12.5 is about the largest tire you can go with without some serious modification or lift.
Old 07-07-2011, 08:25 AM
i have basically the same truck you do and i turn 35x12.50 toyo mts on my truck and have not rubbed yet. i have aftermarket wheels and couldnt tell you the backspacing bc they were on it when i got the truck and they look good so i have never really givin a chit lol you should be fine though. have a buddy that has 35xsomething on his stock wheels with a level kit and he dont rub either (that i have noticed)
Old 07-07-2011, 06:49 PM
Thanks Skooter
Old 07-07-2011, 06:54 PM
What type or type's of leveling kits are you guys runnin'. I want to level mine and was wondering about what kits have good reps.
Old 07-07-2011, 07:10 PM
The factory wheels have a 35-42mm offset and the new wheels have 0mm offset. Is this a problem? Does that put my wheel closer or further out?
Old 07-08-2011, 02:57 AM
I just bough a spring spacer kit off of Ebay and I'm pretty happy with it. Here is the link:
Ford F250 F350 4WD Leveling Lift kit 2005-2010 2.5" | eBay
Old 07-08-2011, 04:18 AM
My Monsters' BS are at +12mm
