Rev X question
Does this stuff only benifit when it is in the oil, or does it seem to fix or stay in the system after the oil is changed? Want to try some but cant really justify that much money if I only get a short term benefit while it is in the system.
Hopefully that makes sense what I am asking. just trying to figure out if I will see and benifits after I change the oil and the rev x is drained out.
As far as I know it will still be a benefit after it's drained
While some will stay in the engine at oil change most will be drained along with the oil. I'm personally going to add the 8oz of Rev-X every other oil change along with the T6 synthetic.
I would add another 4oz every other oil change or so. Preventative maintenance!
It will drain off with the oil. However, if you put it in because of injector stiction it should clean up the injectors pretty quickly. Continued use of a full synthetic motor oil will keep it clean from that point on.
I don't plan to add any more unless I am experiencing a stiction problem. |
It's "effects" are long lasting. What effects? The cleaning. L Sets say you use it for 6,000miles. Now your engine is clean and will stay clean for a long time depending how how often you change your oil. Standard oil no more than 6,000miles, syn, no more than 7,500 miles. Quote:
I have gone 73,000miles with out having cold start issues. I have used syn since ~25,000miles (with a handful of ford 15w-40 from warranty work. I went 5,000miles every time.) and changed my oil every 6,500miles untill I got my bypass. Last edited by smokersteve; 07-07-2011 at 11:25 AM. |
I run synthetic oil, have a bypass oil filter and change reguarly. Sounds like this stuff is worth a shot
I highly recommend it, as do many other people on here.
Get it. I just put some in mine and now it starts real fast and it's good to know that the injectors are benefiting from it.
where is the best place to buy it at?
