Special Tools head removal 6.0 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-05-2011, 03:53 PM Thread Starter
Smile Special Tools head removal 6.0
Does anyone know if u need special tools for a gasket job ? Pull injectors, etc.
volvostep is offline
post #2 of 6 Old 07-05-2011, 05:10 PM
Quoted: 2 Post(s)
What year truck?
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
post #3 of 6 Old 07-05-2011, 06:04 PM Thread Starter
04 f 250 100,000 miles
post #4 of 6 Old 07-05-2011, 06:06 PM Thread Starter
I saw some threads all i really need is the one for the hpfeed line
post #5 of 6 Old 07-05-2011, 07:36 PM
Quoted: 28 Post(s)
The lockdown bolts on the injectors are a torx t-40. You need a long style/screwdriver type but it needs to be torqued 24 ft-lbs. There was a thread started yesterday covering special tools needed for the 6.uh oh...
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #6 of 6 Old 07-05-2011, 07:39 PM
Powerstroke Techie
forddieseldoctor's Avatar
Is your icp sensor located in the right hand valve cover? If it is then you don't need any special tools to remove the heads.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
