EOT vs. ECT - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-01-2011, 09:15 PM Thread Starter
2003kingranch's Avatar
EOT vs. ECT
it was almost 100 today. driving wit with the air on max. cruising 60 my ECT was around 188-190 and EOT was 192-195 sound normal.
then yesterday i had about 1500 pounds of shingles in the back of the truck. my eot was 198-199 and ect 190ish
are my temps ok?
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #2 of 7 Old 07-01-2011, 09:28 PM
dieselkane's Avatar
No issues with those temps. Sounds like your oil cooler is doing fine.
Traded.. 03 6.0 PSD
For.. Black F250 2008 SD LARIAT 6.4 PSD 4x4, Aries Bull Bar, Westin chrome running bars, Dura Liner, B&W Gooseneck hitch, Recon smoked taillights, Icon 4.5" lift, 35" Toyo M/T, etc... Running Spartan Tunes
AFE PG 7, Flo Pro 4" DP Back, thanks to Cobb's Diesel. It has been great so far.
Originally Posted by azkcr View Post
So all that work and you're keeping the trash can of doom on the exhaust?
dieselkane is offline
post #3 of 7 Old 07-01-2011, 09:32 PM Thread Starter
good to hear i just did the oil cooler and egr delete not even a month ago
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #4 of 7 Old 07-01-2011, 11:16 PM
If it is 100* outside and you are under 190* your t/stat is stuck open because a stock Ford t/stat starts to open at 192.2* and is fully open at 219.2 so i think you have a problem the temps are good but will change with a different one plus it is not good to run on the cold side
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #5 of 7 Old 07-01-2011, 11:30 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
2 stroker
219* for the t-stat to open? I don't think I've ever seen coolant temps anywhere near that. I've got a semi-clogged oil cooler and I'm seeing oil temps around 215* and coolant temps around 198-200* and that was in 90* weather today. But I did see a 20* delta today while cruising at 75mph
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #6 of 7 Old 07-01-2011, 11:49 PM
at0075's Avatar
When I'm high way driving my coolant runs about 190 then when I get in traffic it runs anywhere from 190 to 200 and at night around 65 70 out it runs 186ish highway. my temps are all over the place lol. Been thinking about replacing my thermostat here lately just been to lazy
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #7 of 7 Old 07-01-2011, 11:54 PM
You do the math, on the back side of a stock Ford t/stat it is stamped 89/104*C check for your self Celsius to Fahrenheit
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
