Bone stock F250 - Step One: Improve MPG Starting TODAY!
So I've posted in a few other threads about getting the yellow coolant out and putting in the ELC, changing the oil and other fluids, and getting a good baseline on my 2005 F250 6.0. So far so good - temps between ECT and EOT are usually about 9 degrees apart - less than 15 overall so I'm holding off on messing with the EGR.
Today's average MPG: 14.6 on the freeway towing nothing/12.0 or less around town - seems pathetic...but I've moved from sea level (TX) to about 7000 above sea level (with much less humidity, which actually increases this number). I pulled the OASIS and see that a 2006 recall was done where they reprogrammed some aspect of emissions and there's a lot of complaints out there about that having a negative effect on MPG. So with all of that in hand, I took the truck into the I'll keep y'all posted on any changes to the MPG, power, etc... |
From what I understand it's actually the older programs that get the better MPGs than the new ones. Don't know first hand but that's been the general consensus from what I've been able to find.
What version are you running now? Keep us updated as to what flash you get installed and how the numbers turn out for you! |
The older flashing did have better MPG then the new. But for what its worth, the latest programming has two key preventive maintenance features. A cycling of the turbo vanes at idle, and a CEL light when at OT with a ECT/EOT delta of greater than 15*.
Did you already flush your coolant? If so, you may want to keep a keen eye on your temps, as most folks who have flushed without rebuilding the oil cooler have been back under the hood very quickly for that job. If you haven't flushed yet, I would advise waiting and allowing the delta to spread to 15* before making the switch and rebuilding/replacing both coolers. Take that time and learn everything you can, and decide which EGR cooler solution is right for you. Nothing is going to affect MPG more than the way you drive this truck. Keep it civil and you will be fine. However, remember that the 6.0L needs to be worked to keep running. Either put it under a load, and do a few WOT runs about every other week. The reason for this is to build full boost, and fully cycle and clear the vanes in the trubo, along with clearing the EGR valve out a bit. The next thing you'll need to look into is a monitoring device, or gauges, to keep an eye on the internals. Last edited by colo_dually; 07-01-2011 at 10:31 AM. |
I've also been putting my foot into it about 3 times a week during my drive home, and then allowing everything to cool down before shutting the truck down. The excessive idling has me a little concerned but mainly from a $diesel$ perspective. So far this truck has been great! If I can get the code revision that's put on there today, I'll post it here, along with MPG findings. I have a feeling that I might not see significant MPG improvements until I take the EGR out of the picture and maybe get a tuner. **P.S. - Nice Porpoises by the way - my first CTT instructor at Corry Station was on subs for over six years before he and I crossed paths...a long, long time ago. |
