EBP sensor or VGT solenoid question - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-01-2011, 06:35 AM Thread Starter
quick question: I have a 2005 with the lastest code can one tell when a EBP or VGT solenoid is starting to go south or sticking. Here is why I ask when I watch my VGT_DTY% in the insight, I notice when I start the truck it goes to around 76% and then it goes to 85% at high idle. With the new code when it does the vane sweep it works fine except when doing the second sweep part the vanes slowly goes from 70 to 85% and it sometimes sticks around 70% or 75%. Also when coming to a stop sometimes it will go to 85% and then start to back off to say 78% or so. is this normal or is the vgt have issues at the end of the travel? or could it be the ebp senor is seeing pressure that is not there? It seems to move freely through most of the vane travel and my max boost numbers are around 25-27psi. I just put the updated turbo drain and feed tube of the truck. I guess I'm not sure if being a stock truck it should start and goto 85% and then when at rest be at 85%? thanks for any insight.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
