'05 F250 Super Duty shudder on take-off
I just test drove a 2005 F250 with the 6.0 Turbo Diesel and it seems to run great.
The only concerns I have are that on take-off there is a shudder and when cruising at 55-60 mph and then letting off the throttle completely there is a bit of a shudder/harmonic vibration that can be heard and felt through the floor board. It has 4" straight exhaust pipe and is lifted quite high. I was told by a Ford diesel tech it was the exhasut I was feeling but I was wondering if the cause could be in the way it was lifted? Has anyone run in to this before? |
Pinion angle perhaps?
I was thinking that may be the problem. How about the shudder/harmonic vibration at 55-60 mph. Think that may be the same thing?
It's a good possibility. I hope someone else chimes in with some suggestions. How high of a lift are we talking? The vibration at speed could be anything from wheel balance to maybe even driveshaft balance. Hard to say for sure...
Oh, and I also have 4" straight exhaust, and it certainly does not do that. I wonder how the bearings in the differential are. That could do it.
My F350 does that, too. Upon initial acceleration from a stop, you can feel a slight shudder. At highway speeds, you can feel it and hear a droning sound.
On my truck, it's definitely the driveshaft out of balance. This is most likely the case on this truck as well. |
I would nevery buy a problem. Unless its a truck for 10k, stay away.
You can buy a good clean one, lift it and put exhaust on it. Never buy a problem unless you are into restoring old cars. lol |
Here is a picture of it to get an idea of the lift. Someone also mentioned it could be the turbo. The noise/vibration is not constant. I can feel it for about one and a half seconds when the RPM's are dropping.
Well there's many things that could be causing that, the turbo doesn't sound like it'd be the culprit as the straight pipe exhaust would eliminate a backpressure blockage that could cause turbo surge or burping.
My initial thoughts: Driveshaft imbalance Carrier bearing / ujoints shot (crawl under the truck and jerk the driveshaft around, is there excessive vertical and / or horizontal play in it) Wheel aligment / balance (you'd be surprised what a bad balance can do) Pinion angle on the lift (can't see that pic as photobucket is blocked by our company firewalls) Are you getting any check engine lights / codes? |
No check engine lights. It does have an Edge programmer, but I dont think it will keep the MIL from coming on. I can feel that the rear tires are out of balance slightly, but I feel that my concern is coming from the drive line. I will check the carrier bearing and the ujoints when I get a break.
