6.0 high idle - Ford Powerstroke Diesel Forum
Old 06-30-2011, 01:21 PM
6.0 high idle
heard you could wire 6.0 for high idle option.any suggestions.
Old 06-30-2011, 01:39 PM
Welcome to the forums, search is your friend!
High Idle Mod
Old 06-30-2011, 01:44 PM
Yes, depends on the year. 03-04 are different than 05-07.
03-04:
High Idle Mod
05-07:
TheDieselStop.Com - www.thedieselstop.com
Old 06-30-2011, 04:17 PM
If you use the battery charge protect wire your RPM will vary with battery state of charge. If you use the PTO wire it will lock the converter and run at 1200 RPM
Old 06-30-2011, 04:26 PM
Assuming you have the upfitter switches, correct?
Old 06-30-2011, 05:06 PM
No, under the dash behind the fusebox on my 05 you have your choice of sending 12v to the pto wire or the battery charge protect wire. The upfitter switches just make a nice install, however you could use any switched 12v source. I guess it wouldn't even have to be switched,but in that case every time you applied the e-brake in park the truck would idle up. I don't have the wire colors handy right now ,but they were labled very well on my 05. There is also a provision with 3 other wire you can connect to a Potentometer and vary the high idle speed if your application requires that as well. I connected my #4 upfitter switch to the PTO wire with a 6inch jumper and was done in 10 min.
Old 06-30-2011, 05:26 PM
Just curious. I used my upfitter switch.
