Got lucky with engine warranty, but have a question for you knowledgeable guys!
Hey guys/gals,
My engine warranty expires in July so I braught the truck in to get a small oil leak checked out incase it was covered under warranty. It is, and I am lucky because it involves having the engine removed to fix it. Question is I asked that as long as engine is out would they consider putting in new head gaskets and studs. They said they would for about $600 labor. As of now truck only has 33,000 miles and no gasket issues and about a 6-8 degree split in EOC/ECT. Sounds worth it to me! Thaughts? Thanks in advance, Jim |
Man thats a tough call.. If the engine is out anyways, now might be the time to do it. The labor to do it later is prob about $2000.
Not a tough call at all. Do it now.
DO IT!! No question in my mind.
DO IT! My local shops want over $5k to do it "cab off"!
Go for it.600.00 now is a lot better than 2-3000K down the road.Have the egr deleted too while your at it.
Done guys, I gonna get it all done. I asked if that included making sure the heads are true, and tech said yes. I heard Ford gaskets are just as good as anything else, anyone disagree? Anything else I need to make sure gets done on this job?
Thanks Jim |
Have the heads verified for flatness by an independent shop. Oh and the stock gaskets hold up well when the heads are true.
Yup, use the stock head gaskets. Take the heads to a machine shop, don't rely on the Ford procedure.
I wish my dealer would cut me a deal like that BRAVO!!!
