She made it. - Ford Powerstroke Diesel Forum
Old 06-28-2011, 01:51 PM
She made it.
Well my truck turned 100,000 miles sunday.. I have never owned a truck that has had over 50,000. So what are some things I need to look into repairing. I know I need to have the transmission Flushed, but should I also have my diffs changed also? What about ball Joints and U- Joints. Any help or tips are appreciated.
Thanks Shelby
Old 06-28-2011, 02:04 PM
Congrats - You got it broke in!!
Old 06-28-2011, 04:26 PM
Tires, brakes, tranny, diffs and gears, driveshafts, wheels, paint and a new interior!
Just messin' with ya. If the tranny hasn't been flushed in 30k or more definitely flush it. I would change out all the fluids including the brake fluid. That should be done every 2 years but most people never flush the brake system. Keep up with your routine maintenance. She's broke in now like SuperCruty says.
Old 06-28-2011, 04:32 PM
almost!
Old 06-28-2011, 04:34 PM
did you forget blinker fluid?
Old 06-28-2011, 06:24 PM
Thanks Shelby
Check out my link for the trans fluid change.
Change your coolant. do a very good flush
changing the diff and transfercase fluid is a good idea. 75w-90 in the front diff, mercon V for the transfercase, 75w-145 for the rear diff.
flush the brake fluid and change pads.
Old 06-29-2011, 05:16 AM
Thanks for all the information. Going to try to get this done this week or so..Hopefully I dont have the same problems that i had the first 100,000 lol.
Old 06-29-2011, 07:33 AM
change the powersteering fluid!!!
Old 06-29-2011, 08:25 AM
OK I just got the phone with the dealership that has done all the work to my truck.. The trans and t-case I'm going to have them do so I know its done correct. But as far as the diff oil, How hard is that to do your self? what oil should I put in them?
Old 06-29-2011, 08:48 AM
IMO, the trans isn't a bad idea since the dealership can do a full flushing, just make certain they include new filters. The t-case is as simple as an oil change, literally pull a drain plug and then refill. The diffs you have to take off, but same idea as oil change, pull off the differental cover wait for it to drain, bead a gasket, bolt back on, and refill. All 3 are about a 1 or 2 on scale of 1-10.
I used Amsoil for my differentials and have been very pleased. I think it was 75w-90 in the front 4 quarts at about $10 per, and 75w-140 in the rear another 4 qts at roughly $12 per quart.
