Standpipe And Dummy Plug Replacement
I will be replacing mine soon.
DESCRIPTION High pressure oil leakage internally within the engine can eventually lead to no start and hard start conditions resulting from lack of high pressure oil to power the fuel injectors. Ford: 6E7Z-9A332-B International 1882993c93 "PDF" write up I found "Authorized Field Change" http://fedexgroundtruck.arifleet.com...0/AFC08904.pdf FedEx Ground / Home Delivery Fleet Resource Site > Service Bulletins so far the cheapest I have found the 6E7Z-9A332-B so far is: 6E7Z-9A332-B - Ford TUBE - FUEL SUPPLY international dealership in my area is $194, waay too much. Do you guys have any links and advice to doing this? Thanks! |
Herer are some other threads.
Stand-Pipes & Dummy Plugs - Ford Truck Enthusiasts Forums http://www.ford-trucks.com/forums/10...-when-hot.html Last edited by smokersteve; 06-28-2011 at 09:01 AM. |
It's easier than changing an injector.
That price is still having a hard time motivating me to do it. I am giong to give it some more time to find a cheaper price.
For those of you that did the STC fitting, dummy plugs, and stand pipes, did you need the turbo feed line gasket as well? How long of a job was this?
To get to the STC fitting, the turbo would come out. The "turbo mounting kit" (part number 3C3Z-9T514-AD) should be purchased. It has 3 new turbo mounting bolts, drain tube o-rings, supply gasket and bolt, and a few other doo-dads.
Click the link to get it for under 8 bucks. |
I'll get that ordered too, thanks. Is there a procedure for this job? I haven't found one yet....
I think if you order the Bullet Proof SCT fitting there are instuctions how to install it.
