Possible bad sensor? - Ford Powerstroke Diesel Forum
post #1 of 50 Old 06-28-2011, 07:49 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Feedback Score: 4 reviews
Hey guys,
Just got around to checking my voltage. My MAP is 1.231V and my EBP 0.86V with KOEO. With KOER, My EBP jumps to 1.22V. According to a TSB (below) they should be about the same. One of them is obviously bad, but which one? I'm located in Surprise, AZ, which is about 1100 ft.
Typically, this is 14.7 PSI/0.88-0.9 volts at sea level, decreasing one PSI/0.10 volt for every 2000 feet of elevation. It should be within 0.5 PSI of BARO and MAP sensor pressure signals.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #2 of 50 Old 06-28-2011, 08:04 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Well if your engine isn't running you shouldn't have any EBP so it stands to reason that it would jump with the engine running. What was your map at for the KOER?
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 50 Old 06-28-2011, 08:12 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Here's some more info from the AE datalog.
KOEO KOER
Baro 30.82 30.82
MAP 13.92 14.1
EBP 14.3 17.9
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #4 of 50 Old 06-28-2011, 11:59 AM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
After further review, I am thinking my MAP sensor is bad and the PCM commands the turbo to increase EBP so that they are consistent. Does anyone know if there is a way to check?
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #5 of 50 Old 06-28-2011, 12:21 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
MAP sensor reference voltage from the "book"
Key on, engine off 1.35
Low Idle 1.41
High Idle 1.61
Operating range 0.5 - 4.5
Please
You could save the life of a sick child
NYC F-350 is offline
post #6 of 50 Old 06-28-2011, 12:24 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
PID for MAP
key on: 96 (14)
low idle: 96 (14)
High idle: 103 (15)
Operating range: 41-324 (6-47)
kPa (psi)
Don't know if those will help, but that is what I found.
Please
post #7 of 50 Old 06-28-2011, 12:33 PM Thread Starter
Slacker
Evil Eye's Avatar
Quoted: 214 Post(s)
Hmmm, well the MAP signal matches those from the book. Do you also have the EBP reference values? I really appreciate your assistance.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
Evil Eye is offline
post #8 of 50 Old 06-28-2011, 12:41 PM
PGreenSVT's Avatar
What issues are you having Shawn?
RIP Mitch
the Org crew
post #9 of 50 Old 06-28-2011, 12:43 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
EP reference voltages per the book
Key on: 1.0
Low idle: 1.2
High Idle: 1.4
operating range: 0.4 - 4.7
pid's to follow
Please
post #10 of 50 Old 06-28-2011, 12:48 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
EP sensor pid:
Key on: 103 (15)
Low Idle: 110 (16)
High Idle: 110 (16)
Operating range: 55-607 (8 - 88)
kPa (PSI)
There is a pid for EP voltage as well:
EP_V:
Key on: 0.8
low idle:1.2
High Idle: 1.3
operating range: 0.4- 4.7
Please
