Will a tuner replace an egr delete?
I am interested in buying the SCT SF3 Tuner. I noticed on the descriptions tab it states "Removes the Exhaust Gas Recirculation functions from normal engine operation." Does that mean if I install this tuner I don't need to do an EGR Delete?
If not, what does that mean? |
I just talked to their tech support, and they said it does not replace the EGR Delete, but it stops about 90% of the effect.
So, that tells me that is would be a good idea to get the tuner now, to at least minimize the effect of the EGR valve, watch my gauges, and when my oil cooler starts to go, at that time replace the oil cooler & do the delete kit. (Unless I end up with an extra Stack of money & I can do it sooner). Sound like a reasonable approach? |
Will recommend to buy a data monitor of some sort! ScanGuage II is a great option for data monitoring.
Need to monitor oil temp and coolant temp. Those are critical for the 6.0L owners! Also the ScanGuage can monitor FICM voltage, ICP pressure, Boost, etc. Nice tool for less than 200 bucks
Sounds like a good plan. Just watch those gauges.
Don't think I need the Scan Gauge 2, since I now have EOT, ECT, ExT, & Fuel Pressure gauges. The basic Scan Guage looks like it has nice fuel monitoring stats though. However, since my on-board computer monitors trip & instant MPG, the only thing that would really add is being able to monitor the actual cost, isn't it?
Anyone ever compare the accuracy of the stock monitor compared to one of these? |
As long as you have gauges other than the stock "idiot light" style gauge, you would be ok to watch the eot/ect spread.
The scangauge2 is quite the tool for under 200 bucks, tough to beat the cost versus what it can monitor that you can't any other way (beyond a much more expensive system). |
Here are just a few gauges the ScangaugeII can read. These are Xgauges, and need to be entered into the SGII. Very simple once you have done a couple.
FICM Vehicle Power (Volts) (Should be 12 Volts, should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03) TXD: 07E02209CE RXF: 0462450906CE RXD: 3010 MTH: 006401000000 NAM: FVP FICM Logic Power (Volts) (Should be 12 volts) TXD: 07E02209CF RXF: 0462450906CF RXD: 3010 MTH: 006401000000 NAM: FLP FICM Main Power (Volts) (Should be 47-48) Your FMP should never dip below 45. If it does, your FICM is toast and needs repaired or replaced. TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 006401000000 NAM: FMP VGT Duty Cycle (%) TXD: 07E022096D RXF: 04620509066D RXD: 3010 MTH: 00647FFF0000 NAM: VGT Engine Oil Temp TXD: 07E0221310 RXF: 046245130610 RXD: 3010 MTH: 00090005F05F (00090005FFD8 alternate MTH found) NAM: EOT Trans. Fluid Temp TXD: 07E1221674 RXF: 046205160674 RXD: 3010 MTH: 000100080000 NAM: TFT Horsepower TXD: 00 RXF: 400080000000 RXD: 0000 MTH: 000A00240000 NAM: HPR Inj. Control Press. (ICP / HPOP) TXD: 07E0221446 RXF: 046205140646 RXD: 3010 MTH: 003900640000 NAM: IPR ICP Voltage (Volts) TXD: 07E02216AD RXF: 0462451606AD RXD: 3010 MTH: 004827100000 NAM: ICV IPR Duty Cycle TXD: 07E0221434 RXF: 046285140634 RXD: 3008 MTH: 0DCA03E8000A NAM: IPR % Throttle Position 1 (Volts) TXD: 07E0220917 RXF: 046245090617 RXD: 3010 MTH: 006404000000 NAM: TP1 Note: Voltage of the ETC Throttle Position Sensor number 1 Throttle Position 2 (Volts) TXD: 07E0220918 RXF: 046245090618 RXD: 3010 MTH: 0064040000000 NAM: TP2 Note: Voltage of the ETC Throttle Position Sensor number 2 ---------------- Throttle Position Desired (Degrees) TXD: 07E022091A RXF: 04624509061A RXD: 3010 MTH: 0064020000000 NAM: TPD Note: ETC Commanded Throttle Angle, in degrees. Throttle Position Actual (Degrees) TXD: 07E022093C RXF: 04624509063C RXD: 3010 MTH: 006402000000 NAM: TPA Note: The measured throttle angle from the throttle sensor inputs. EGR Duty Cycle (Percent) TXD: 07E022166E RXF: 04620516066E RXD: 3010 MTH: 006440000000 NAM: EGR EGR Throttle Position Control Signal TXD: 07E022096C RXF: 04620509066C RXD: 3010 MTH: 00647FFF0000 NAM: ETP EGR Valve Position (mm) TXD: 07E022096A RXF: 04620509066A RXD: 3010 MTH: 000100010000 NAM: EVP Note: EGR Valve Position in hundredths of a millimeter, where 0 mm indicates a closed EGR valve position. EGR Valve Position Desired (%) TXD: 07E02209D2 RXF: 0462050906D2 RXD: 3010 MTH: 00647FFF0000 NAM: EVD >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> EGR Valve Position Measured (%) TXD: 07E02209FE RXF: 0462050906FE RXD: 3010 MTH: 00647FFF0000 NAM: EVM Note: MEASURED EGR Valve Position, in %, where a low value indicates a closed EGR valve (0 EGR flow), and a high value indicates an open EGR valve. EGR Valve Position (Volts 0-5) TXD: 07E022167E RXF: 04620516067E RXD: 3010 MTH: 000133330000 NAM: EGV Camshaft & Crankshaft Sync (1 = in sync, 0 = not in sync) TXD: 07E02209CD RXF: 0462050906CD RXD: 3000 (3001 alternate) MTH: 000100010000 NAM: SYC Intake Air Temperature 2 (Fahrenheit) TXD: 07E02216A8 RXF: 0462051606A8 RXD: 3010 MTH: 000100010000 NAM: IA2 Manifold Air Temperature (F) TXD: 07E02216E0 RXF: 0462051606E0 RXD: 3008 MTH: 00090005FFD8 NAM: MAT Barometric Pressure TXD: 07E0221127 RXF: 045285110627 RXD: 3008 MTH: 003100500000 NAM: BMP Exhaust Back Pressure TXD: 07E0221445 RXF: 046285140645 RXD: 3010 MTH: 001D00500000 NAM: EBP Fuel Level TXD: 007E02216C1 RXF: 0462451606C1 RXD: 3010 MTH: 000101480000 NAM: FL Volume Fuel Desired TXD: 07E0221411 RXF: 046245140611 RXD: 3010 MTH: 006400100000 NAM: VFD Mass Fuel Desired (Milligrams Per Stroke) TXD: 07E0221412 RXF: 046205140612 RXD: 3010 MTH: 000100100000 NAM: MFD Engine Run Time (Minutes) TXD: 07DF011F RXF: 0441051F RXD: 2810 MTH: 0001003C0000 NAM: ERT >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Fan Speed Sensor (RPM) TXD: 07E022099F RXF: 04620509069F RXD: 3010 MTH: 000100040000 NAM: FSS Fan Speed Sensor Duty Cycle (%) TXD: 07E022091F RXF: 04624509061F RXD: 3010 MTH: 013103E80000 NAM: FDC Manifold Absolute Pressure (PSI) (BOOST) TXD: 07E0221440 RXF: 046285140640 RXD: 3010 MTH: 012203200000 NAM: PSI MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost. With a little tweaking you can adjust this to read boost as you said. To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table 14.0 -- FF74 14.1 -- FF73 14.2 -- FF72 14.3 -- FF71 14.4 -- FF70 14.5 -- FF6F 14.6 -- FF6E 14.7 -- FF6D 14.8 -- FF6C 14.9 -- FF6B 15.0 -- FF6A So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running. Injector Timing Before Top Dead Center (Degrees) TXD: 07E02209CC RXF: 0462850906CC RXD: 3010 MTH: 000A00400000 NAM: ITM Fuel Injector Pulse Width (Microseconds) TXD: 07E0221410 RXF: 046205140610 RXD: 3010 MTH: 000800010000 NAM: FPW Fuel Injector #1 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3001 MTH: 000100010000 NAM: FI1 Fuel Injector #2 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3101 MTH: 000100010000 NAM: FI2 Fuel Injector #3 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3201 MTH: 000100010000 NAM: FI3 Fuel Injector #4 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3301 MTH: 000100010000 NAM: FI4 Fuel Injector #5 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3401 MTH: 000100010000 NAM: FI5 Fuel Injector #6 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3501 MTH: 000100010000 NAM: FI6 Fuel Injector #7 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3601 MTH: 000100010000 NAM: FI7 Fuel Injector #8 Commanded (On/0ff) TXD: 07E02209EF RXF: 0462250906EF RXD: 3701 MTH: 000100010000 NAM: FI8 >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Cylinder #1 Cumulative Misfires TXD: 07E022160E RXF: 04620516060E RXD: 3010 MTH: 000100010000 NAM: 1CM Cylinder #2 Cumulative Misfires TXD: 07E022160F RXF: 04620516060F RXD: 3010 MTH: 000100010000 NAM: 2CM Cylinder #3 Cumulative Misfires TXD: 07E0221610 RXF: 046205160610 RXD: 3010 MTH: 000100010000 NAM: 3CM Cylinder #4 Cumulative Misfires TXD: 07E0221611 RXF: 046205160611 RXD: 3010 MTH: 000100010000 NAM: 4CM Cylinder #5 Cumulative Misfires TXD: 07E0221612 RXF: 046205160612 RXD: 3010 MTH: 000100010000 NAM: 5CM Cylinder #6 Cumulative Misfires TXD: 07E0221613 RXF: 046205160613 RXD: 3010 MTH: 000100010000 NAM: 6CM Cylinder #7 Cumulative Misfires TXD: 07E0221614 RXF: 046205160614 RXD: 3010 MTH: 000100010000 NAM: 7CM Cylinder #8 Cumulative Misfires TXD: 07E0221615 RXF: 046205160615 RXD: 3010 MTH: 000100010000 NAM: 8CM Gear (Transmission Gear) TXD: 07E12211B3 RXF: 0462051106B3 RXD: 3008 MTH: 000100020000 NAM: GER Vehicle Speed Sensor (MPH) TXD: 07E02211C1 RXF: 0462051106C1 RXD: 3010 MTH: 000102000000 NAM: VSS Accelerator Pedal Position (%) TXD: 07E02209D4 RXF: 0462050906D4 RXD: 3008 MTH: 000100020000 NAM: AP% DTC Count (Diagnostic Trouble Code Count) TXD: 07E0220200 RXF: 046205020600 RXD: 3008 MTH: 000100010000 NAM: DTC VREF (Calibration Voltage Input) TXD: 07E0221155 RXF: 046245110655 RXD: 3010 MTH: 006433330000 NAM: CVI Net Torque into Torque Converter (Ft-Lbs) TXD: 07E02209CB RXF: 0462050906CB RXD: 3010 MTH: 000100010000 NAM: TRQ |
Dang, that's a lot of info.
Those are just some. A few more have been added along the way. So, you can see why $160 for this gauge is pretty amazing. Also, right now if you join (for free) cleanmpg.com, you can pick one up for $135. They are having a group buy.
CleanMPG, An authoritative source on fuel economy and hypermiling Scroll down and keep your eye on the left side. It will show a group buy on it. |
