bummed, whats the deal? ect/eot deltas do i need to worry? - Ford Powerstroke Diesel Forum
Old 06-26-2011, 11:41 AM
So as the title says I'm pretty bummed. About 1000 miles ago I went through the whole restore vc9 flush Nd clean. My eot was regularly 15 degrees hitter 30 + at times. So at the same time as the flush and clean I also replaced the oil cooler. Got the car elc conc and distilled water. Followed everything to a t. Went on a 5 hour trip to philly this weekend and cruising at 2300 rpm on cruise at about 75 nor towing, my eot was 10-13 degrees hotter than ect. 190 ect constant. Eot anywhere from 193 to 203. Do I still need to worry, or is there something else I need to do?
Sig shows my mods. Thanks.
Old 06-26-2011, 12:51 PM
You don't have an EGR cooler and given it was most likely a hot day and your were running the AC. I wouldn't worry about it to much just yet. If you don't have one get a coolant filter.
Old 06-26-2011, 01:57 PM
Yes hot day and ac on. Why would the egr cooler effect oil temps?
Sorry for the double posts. Mods can either merge the 2 or delete 1
